Motor Oil throwing codes
Old Feb 7, 2011 | 10:45 PM
redtruck2500's Avatar
redtruck2500
Default Motor Oil throwing codes
A buddy of mine heard if you are not using the correct vicosity oil in his 2011 Hemi , they will throw engine codes . Any thing to this ?
Old Feb 7, 2011 | 10:55 PM
05Dakotaho's Avatar
05Dakotaho
Rods......
Old Feb 7, 2011 | 11:27 PM
DwRam's Avatar
DwRam
Talking
Ya caught me. I've been runnin' 20w50 in your buddies HEMI. His warranty is toast....
Old Feb 7, 2011 | 11:31 PM
redtruck2500
BS then ?
Old Feb 8, 2011 | 01:03 AM
HEMI5150's Avatar
HEMI5150
BS then ?
No, not BS...! They can send out an oil sample, have it tested.
If it isnt what supposed to be in the engine, ther goes the warranty...!
Also with the MDS hemi, anything but 5w20, the MDS wont work properly.
Not that anyone here gives a ratsazz about mds for all the issues people **** and moan about with it.
Myself, i would at least go by what the manufactuer recommends until the warranty expires, its your choice, do what you want.
Old Feb 8, 2011 | 09:09 AM
redtruck2500
As long as the check engine light does not come on , he's good to go .
Old Feb 8, 2011 | 10:09 AM
WNDERR's Avatar
WNDERR
5W-20 is VERY IMPORTANT in the 2011's. And change it according to MFRS recommendation, or when the truck tells you to.
Old Feb 8, 2011 | 10:44 AM
Talon_66's Avatar
Talon_66
i run 0w20
Old Feb 8, 2011 | 01:50 PM
BigBlueEdge's Avatar
BigBlueEdge
5W-20 is important to every 5.7L Hemi engine with MDS that Chrysler has produced (at least as early as the 2005 Jeep Grand Cherokee where I first was exposed to MDS). If you don't have 5W-20 your engine may not enable MDS.
Rob
Old Feb 8, 2011 | 02:42 PM
5.7x28mm's Avatar
5.7x28mm
I realize that I'm just an idiot that doesn't understand a lot of these things, but what would be the point of using an oil viscosity other than what Chrysler recommends? Is there any real advantage worth risking your warranty, and/or F'ing up your engine?
