leveling kit and 33's
Old Feb 13, 2011 | 02:25 PM
  #21
InterpunX's Avatar
InterpunX
Originally Posted by section88
I just started getting 4x4 wobble with no lift + 17" winterforce tires. My wife has too. His n hers club. What's the wobble from? It wasn't there last year.
Well it depends. Does it wobble when only in 4x4 or 2wd also. If it does it in 2wd also it could be your tires unbalanced, or could also be snow or ice stuck on the rims. If its not that and does it only in 4wd its somewhat normal, depends the surface your on, if you drive with 4x4 on pavement then it would be normal especially when accelerating. I noticed my truck would have a lil wobble when it was stock in 4wd. I live up north and the only time i use 4wd is when theres alot of snow in town. When i hit the highway i put it in 2wd unless theres a blizzard outside. Easier to regain control if your in 2wd than 4x4, i talk from experience i rolled my ram that way being in 4x4. Anyways check those out and lemme know. I it a bad wobble or you feel a lil vibration in the steering wheel?
Old Feb 15, 2011 | 10:48 AM
  #22
rdubs20's Avatar
rdubs20
Hopefully putting on the HBS leveling kit this weekend I will post picks when I am done. Will 285x60x20's fit without any rubbing issues?
Old Feb 15, 2011 | 09:03 PM
  #23
Stuck2theAxles's Avatar
Stuck2theAxles
i have a 2wd with a 2 inch leveling kit and 33x12.50x20s toyo mts on the stock 20s and it runs greats the only issue is it rubs on the sway are at full over
Old Feb 15, 2011 | 09:18 PM
  #24
RamJam2010's Avatar
RamJam2010
I am no expert, but from everything I read so far you should have no trouble with that size. My HBS kit should be here tomorrow or thursday, and I am putting 285/65/20 BFG AT's on my ram with factory 20's after the install (when they arrive, most likely not till next week). I took my stock pics today, and will try to post pics stock, with the level, and then with the level and tires. I chose the setup because of what I read from other members here. Hope this helps! By the way, InterpunX your truck is BADA**, nice work!!!
