TPMS Error from HID's?
Old Feb 14, 2011 | 10:41 PM
steak59's Avatar
steak59
Put some tune up grease on ur ballast wrap it up in Aluminum foils!
Old Feb 15, 2011 | 01:09 PM
reeseonfire's Avatar
reeseonfire
My TPMS light has been on solid for days now. I checked my tires, all are normal, and filled with nitrogen so I know its not the change in weather or anything thats causing this.
From what you guys say tho, your TPMS lights dont stay on solid? They come on after an amount of time?
Old Feb 15, 2011 | 06:15 PM
Gary C.'s Avatar
Gary C.
Lol! I'm actually going to try moving them this weekend and wrapping them in foil - I figure a little shielding can't hurt!
Even more interesting, I took a road trip today (about 100 miles interstate each way) and the error cleared itself. No idea why, but I expect when I use the lights again it'll flare up...
Old Feb 15, 2011 | 07:19 PM
BigBlueEdge's Avatar
BigBlueEdge
My light only comes on for a second when the headlights or fogs turn on. Both sets are HIDExtra.
Rob
Old Feb 15, 2011 | 07:39 PM
plumcrazy73's Avatar
plumcrazy73
rather then standard foil, try the quietening mat that has foil on it.
Old Feb 15, 2011 | 08:00 PM
reeseonfire
I probably wouldn't do that if the ballasts get hot. Heat is the enemy of power.
Old Feb 15, 2011 | 08:19 PM
Gary C.'s Avatar
Gary C.
For me, until I installed the HID Extra lights my TPMS light only came on for maybe a second when the lights came on... after the HID Extras it's on flashing non stop.
Old Feb 16, 2011 | 07:37 AM
plumcrazy73
true did not think of that
Old Feb 16, 2011 | 07:58 AM
TDTIPMO's Avatar
TDTIPMO
Do you have HID's? Typically, if there is a tire pressure problem, once you start you truck, you will get the chimes and the flashing TPMS. Then after a few seconds it will stay solid. Of course if you don't have HID's and you checked that your tire pressure being up to the correct level, I would say you have a bad sensor or a lose connection.
Old Feb 16, 2011 | 10:10 AM
72combo's Avatar
72combo
All these problems I read about when lifting your truck or putting HID's on them...seems to be a couple of mods that need some refining before I would just bring on grief.
