Amps Rack Installation
Old Feb 14, 2011 | 01:29 AM
biker_ahoy's Avatar
biker_ahoy
Default Amps Rack Installation
So I've been working on this in my spare time for the last few months and it is finally almost finished.
This is for my 2010 Ram.
I picked up some 1/16" steel plate and had it bent for mounting porpose.
After getting the mounting holes lined up and drilled/grinded out for mounting under the rear seat brackets. I am using the existing bolts from the seats and middle seatbelt roller.
I went to work getting the Amps mounted up. did a black paint job on the plates and I am now just working on the finishing of running the wires to the doors. I am replacing the stock door speakers with aftermarket 6x9 component's for the front and rear of the truck. the front tweeters will be installed in the A-pillers and the rears I am still deciding of the exact location to mount.
I Have already installed an aftermarket single Din Clarion deck and run all the pre-outs under the center console and under the rear carpet to the back of the truck for hook up to the amps. Everything is in place. I am now just waiting on door speakers to hook everything up.
I am also building a custom sub box to go right behind the center console. it will be centered on the floor in the back.
Here are a bunch of the pics.
Removing Rear Seats
Fitting and fabing mounting.
Clearance check!
First Plate
Second Plate
Mounting holes in place
Painted
Amps mounted
Capacitor Mounted
I will have More pics to come as I get more done!
Old Feb 14, 2011 | 02:21 AM
JonathanA's Avatar
JonathanA
Sweet!
