recon rear light bar
Old Feb 23, 2011 | 05:48 PM
redram2008's Avatar
redram2008
Default recon rear light bar
got it on today & wired and it works ! i ran a four prong pig tail off the wiring harness then taped into the hot wire and reverse wire works great and leaves the plugs on the bumper open for other uses will take pic's tonight anybody got access to cab lights for the 2011 ? just a stock recon pic
Old Feb 24, 2011 | 04:11 AM
trashman139's Avatar
trashman139
are you still able to get to the spare tire winch opening with the lights there did you cover it up?
Old Feb 24, 2011 | 10:20 AM
redram2008's Avatar
redram2008
hey trashman that's what i do haul trash yes it does cover the hole but there are little screws that hold it on that you can unscrew the light bar to access the winch hole never had to do it on any truck that i have had just lucky i guess
Old Feb 24, 2011 | 05:20 PM
trashman139
redram i guess we have similiar taste all the way around diggin the inferno red same as mine.. i had a 60'' light bar in my hand and decided against it because of the spare winch hole location. might have to go get it it looks pretty good. how hard was it to splice the pigtail into the harness.
Old Feb 24, 2011 | 06:14 PM
redram2008's Avatar
redram2008
does your light bar have the reverse lights ? not hard to do at all ! just get the 4 prong pig tail that plugs into the light bar then get a test light do you have the tow package on your truck with the 4/7 pin hook ups ? just take off the plastic clip for the spare winch and be real careful were you mount the light bar as there is not much clearance in between the light and tailgate !!! hell i work for republic circus/services drive a frontloader in nevada
Old Feb 24, 2011 | 07:19 PM
trashman139
yep tow package with 4/7 but i want to leave all that stuff alone what i was wanting to do is to splice into the 4 and hide the actual connection behind the bumper. I am lucky enough to work for waste management brand new Mack frontloader sure wish i was in NV. not OH
Old Feb 24, 2011 | 07:35 PM
redram2008's Avatar
redram2008
yep tow package with 4/7 but i want to leave all that stuff alone what i was wanting to do is to splice into the 4 and hide the actual connection behind the bumper. I am lucky enough to work for waste management brand new Mack front loader sure wish i was in NV. not OH
that's what i did tap into the wiring harness then just plug the light in behind the bumper pulled my trailer today with no problem's with the lights . we run auto car trucks out here we have a new one and a junker as a backup we are 90 miles south of Vegas
Old Feb 24, 2011 | 07:39 PM
trashman139
all our auto is recycle im running stop to stop 900 plus stops a day anywhere from 8 to 15 tons a day depending on the route and area. im going to go pick the light bar up tomorrow and give it a go hope it turns out.
Old Mar 30, 2011 | 07:31 PM
BigBlueEdge's Avatar
BigBlueEdge
What's the best way to tap into the trailer wiring harness to make a quality connection that is sealed from the elements? I don't want to use the 'vampire clip' connectors. I prefer the idea of soldering things together but unless I totally cut the stock wiring I can't get heat shrink on to seal it. Other ideas?
Thanks,
Rob
Old Mar 30, 2011 | 08:42 PM
redram2008's Avatar
redram2008
Thanks,
Rob
i just used the blue wire clips and taped it up real good much easer if you sell the truck to remove it never had any trouble but i live in the dry desert . just skin the wires then solder them up
