vandalism....
Old Mar 4, 2011 | 04:27 PM
moosefire66's Avatar
moosefire66
Default vandalism....
Well I go to walk out to my truck today to go to work, when I find some nice green spray paint on my passenger side bed side just before the taillight. Needless to say I'm pretty pissed off.
Does anyone have a good method to getting off the spray paint without removing the factory paint?
Old Mar 4, 2011 | 04:44 PM
BigBlueEdge's Avatar
BigBlueEdge
If it's fresh you can probably take it off with some type of cleaner or light polish. Something like Goo Gone or Goof Off as a cleaner. That shouldn't hurt the factory paint, though you'll need to wax the area again once complete. Or try some 3M Fine Cut rubbing compound as the polish.
Bummer to hear, by the way. Some people just suck.
Rob
Old Mar 4, 2011 | 05:08 PM
moosefire66
Ok. I do have some rubbing compound, as well as some goo gone so hopefully it comes out. And I don't know how fresh it actually is... I touched it when I first saw it and it was already dry. I now am at work, so it will be atleast 12 hours from now before I can try to work on it...
Old Mar 4, 2011 | 05:44 PM
WNDERR's Avatar
WNDERR
Easy Off oven cleaner. A SMALL AMOUNT ON A WET RAG, rinsing the surfavce with water frequently ------ go very slow..............
Old Mar 4, 2011 | 06:44 PM
POWER SEDAN's Avatar
POWER SEDAN
I'd like to use the vandalism actors face to buff out the the paint personally! It's to sad some people just don't have a real life!
Old Mar 4, 2011 | 06:50 PM
CarGuyOhio's Avatar
CarGuyOhio
Yea, not hard to remove. Worst case some 1500 grit sand paper, water, rubbing compound and polishing compound.
If I had to pick that is MUCH better than a key.
Old Mar 4, 2011 | 10:12 PM
h1painter's Avatar
h1painter
Go to an automotive paint store, get some reducer like Dupont 3812, use a soft rag. Spray paint usually wipes right off.
Old Mar 4, 2011 | 10:36 PM
moosefire66
I sure hope its as easy as you guys make it seem! I'm going to try it around 4am when I'm out of work. Ill keepyou guys posted .....
Old Mar 5, 2011 | 12:14 AM
HEMI5150's Avatar
HEMI5150
If you find out who did it, stab them right in the eyes with an ice pick
Fuggin loosers....!!!!!!!! If it were my truck, someone would get hurt permenatly.
Try some enamel reducer, or some denatuerd alchohol to get the spray paint off.
DO NOT USE ANY LAQUER THINNER`S, IT`LL EAT THE CLEARCOAT AND PAINT...!
Make sure you wax the pizz out of it when you`re done gettin the spray paint off.
Some good carnuba wax`s will actually lift the spray paint off as well.
Silicone wax wont, it`ll just bury it into the clearcoat worse.
Old Mar 5, 2011 | 03:25 AM
moosefire66
Well I got off work early and got to stripping paint. Much easier than anticipated. Im not sure if it was because my truck was dirty, maybe crappy paint, who cares, all it took was a towel and it wiped right off. I tried a power washer first, but didnt really do anything. None-the-less, within three minutes i was all done. Here are some pictures of before/after...
