How Tall is your levelled Truck?
Old Mar 10, 2011 | 01:18 PM
Sean2010's Avatar
Sean2010
Default How Tall is your levelled Truck?
Hey Guys I just want to see how tall your trucks are after you level them with the stock tires still. I really want to install a kit soon but I worry about getting into underground parking lots some are higher than others but if someone could measure it for me that would be great. Oh and I know there are different kits out there with different levelling heights so please include which kit your running.
Thanks for your help guys
Old Mar 10, 2011 | 03:38 PM
hotrod929's Avatar
hotrod929
I just did the bilstein leveling shocks up front with 2" springs in the back as well as 35" tall tires. I am just a bit under 7' I still fit in the automatic car wash and most garages.
HotRod
Old Mar 10, 2011 | 04:11 PM
BigBlueEdge's Avatar
BigBlueEdge
I know you're looking for actual measurements from people with a leveling kit, but one way you could mock it up yourself is to park on a level surface and put a floor jack under the front and raise up the front end until the tire-to-wheel well space is even on front and back. That should be pretty much how your truck will sit with a leveling kit. Then you can measure overall truck height.
Rob
Old Mar 11, 2011 | 07:55 AM
matt3's Avatar
matt3
Mine has a 2.5" kit with stock tires and I have no problem getting into parking garages.
Old Mar 11, 2011 | 05:17 PM
Sean2010's Avatar
Sean2010
Thanks guys for the info But im looking for a actual height because every underground is different. I have a townhouse right now and my truck fits no problem I could install a 6 inch liftkit with 40" tires and I would still be ok but I am selling the place and buying a condo and I worry I won't fit if I level the truck and install 35" and like I said every underground is different so I kinda need to know what I'm working with
