Auto door lock and seat belt chime cancel
Old Mar 12, 2011 | 08:11 PM
markgpz's Avatar
markgpz
Default Auto door lock and seat belt chime cancel
What is the procedure to override (remove) the chime from going off when the seat belt is not fastened while moving, and to stop the door locks from locking when the truck is initially put into D and moving?
2011 Ram 1500
Old Mar 12, 2011 | 09:03 PM
BigBlueEdge's Avatar
BigBlueEdge
The procedure for the seatbelt should be in the manual. The door lock thing is a setting in the EVIC, I believe.
Rob
Old Mar 12, 2011 | 11:32 PM
Patsfan's Avatar
Patsfan
2010 owners Manual - Page 50
BeltAlert
 can be enabled or disabled by your authorized
dealer or by performing the following procedure:
NOTE:
The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. Chrysler Group LLC does not recommend
deactivating the BeltAlert
1. With all doors closed and the ignition switch in any
position except ON or START, buckle the driver’s seat
belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Reminder Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 60 seconds, ending with the seat belt
buckled.
NOTE:
Watch for the Seat Belt Reminder Light to turn
on while the seat belt retracts and turn off while rebuckling
the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
BeltAlert
 can be reactivated by repeating this procedure.
