Radio swap
Old Apr 8, 2011 | 10:25 AM
RoadRashRon's Avatar
RoadRashRon
Default Radio swap
Can anyone tell me if all high speed bus REN, RBZ or RER radios will work in a 2010 Ram?
Or if I have to have a perticular part number to work.
There seem to be a ton of different part numbers for both low and high speed.
It will be replacing a RES.
Thanks
Old Apr 8, 2011 | 10:54 AM
10RAMSPORT's Avatar
10RAMSPORT
RBZ works, I swapped mine a few months ago.
Old Apr 8, 2011 | 11:02 AM
RoadRashRon
So as long as its a high speed bus it works?
How was installation? I havent looked that hard, does the dash come apart rather easily?
Old Apr 8, 2011 | 11:43 AM
10RAMSPORT's Avatar
10RAMSPORT
Yeah, has to be high speed. Mine was acutally out of a 10 Jeep Grand Cherokee, had to make some modifications to the mounting, but it worked out. If you actually get one for a Ram you should be plug and play.
Radio Removal Instructions
http://www.wkjeeps.com/sound/2009_Do...io_Removal.pdf
Old Apr 8, 2011 | 01:24 PM
BigBlueEdge's Avatar
BigBlueEdge
My 2010 Sport came with an RBZ radio. It was built in May. So, yes, it can work.
Rob
