Oil Change Indicator/Chime
Old Apr 12, 2011 | 06:07 PM
USAF1's Avatar
USAF1
Default Oil Change Indicator/Chime
Ok, so let me see if I got this right. Due to my driving habits, I got the oil change light/chime at around 2500 miles. So if I want to keep my warranty intact, I will probably have to change my oil every 2500 miles?? And I thought changing oil every 3,000 miles was too often.... I guess the only way I'll get to the 6,000 mile oil change limit, is if I only drive it on the freeway on long trips.
Old Apr 12, 2011 | 06:55 PM
BigBlueEdge's Avatar
BigBlueEdge
The recommended oil change intervals are in the manual. That's what the factory would judge things by if there was an oil-related warranty issue to deal with. The computer's oil life monitor attempts to be 'smarter' than the manual but you're not obligated to obey it. Besides, I think the 2500 mile interval is kind of default for the first change, then it gets longer.
Rob
Old Apr 13, 2011 | 01:02 AM
mike2810's Avatar
mike2810
Mopar Mag had a good write up on the oil monitoring light.
http://www.moparmagazine.com/2009/ma...ing_light.html
There are six inputs used by the PCM. The factors which indicate severe use (and a shorter oil change interval) for each of these inputs are listed below:
  • Ambient temperature – extended periods of low temperature operation
  • Average vehicle speed – stop and go driving
  • Engine run time – prolonged idling
  • Trip length and coolant temperatures – short trips
  • Engine speed and load – trailer tow usage
  • Flex-fuel percentage – ethanol percentage of more than 60%
If severe usage is determined, the oil change message is activated at 2,500 miles; otherwise, the message is not displayed until additional mileage has accumulated.
I have had the change oil light come on at 2500 miles, That was a time in which I did mostly very short trips (1-3 miles), during the winter. Most of the time I make it to the 6 month (3 to 5 K) without the light coming on, but I change the oil anyway at 6 months. Bottom line I only need to do 2-4 oil changes per year. with following the manual or light monitor (6 months or X miles, whichever comes first.)
