Aftermarket Rims on Ram 1500
Old Jun 3, 2011 | 04:38 PM
MC2000's Avatar
MC2000
Exclamation Aftermarket Rims on Ram 1500
I just purchased a pre-owned '10 Ram Laramie that had some 22" Gitano rims on it. It had a bit of wiggle in it, so I took it Discount Tire to get those big wheels balanced. They informed me that Ram trucks have "flared" lugs that prevent these aftermarket rims (with a completely flat mounting surface) to fit snugly or firmly against the hub, which is what was causing the vibration. Thus, creating a safety issue - they wouldn't even balance the rims.
So, should I try to fight the fight with the dealer and see if they will replace the faulty rims with OEM Ram wheels, or is there an off-the-shelf solution to this problem? Has anyone else heard of this? I've scoured the net with Google and can't really find anything relating to this specific issue.
Old Jun 3, 2011 | 08:12 PM
HEMI_ROM's Avatar
HEMI_ROM
I have not heard of this. I rotated my tires a while back but didn't notice any flared or raised area around the lugs. Maybe its there but not easy to see? Hope it taren't so casue looks like I will be needing aftermarket rims.
Old Jun 3, 2011 | 11:02 PM
HammerZ71's Avatar
HammerZ71
Yep, gotta use a conical lug nut, some aftermarket wheels will not take a conical (also known as an acorn nut).
You can try the dealer because it's a HUGE safety issue, but dealer contracts on used vehicle sales usually have some fine print about aftermarket parts installed by the previous owner being accepted at the purchasers risk. I know here, they have you initial the sheet that says you've inspected the vehicle you are purchasing and accept the risks of non-factory parts, it's one of the 11 or 12 papers they slide at you over the finance desk to initial...
Old Jun 4, 2011 | 12:07 AM
11RamR/T's Avatar
11RamR/T
Hubcentric adapters are critical for aftermarket wheels!
Old Jun 5, 2011 | 11:24 AM
mdram43's Avatar
mdram43
i would head back to the dealer stat, because fine print or not, they just sold you an unsafe vehicle. pretty sure that will supersede any fine print bs. i dont see how thats much different than lemon laws
Old Jun 6, 2011 | 10:14 PM
huntergreen's Avatar
huntergreen
should be covered by warranty. looks like you will be getting new wheels!
Old Aug 26, 2011 | 03:25 PM
72combo's Avatar
72combo
11RAM R/T got you private message but cannot reply you must have it blocked or shut off or something send me an email address.
