Dead FOB?
Old Jun 15, 2011 | 05:21 PM
bmwbutch's Avatar
bmwbutch
Default Dead FOB?
Will your truck still crank if the battery is dead in the FOB? Can't find this owners manual or this site.
Old Jun 15, 2011 | 07:46 PM
bmwbutch's Avatar
bmwbutch
Default Answer to my own question
Problem started when battery got weak in wife's Challenger FOB.
Found this site: http://www.sequentialtaillights.com/...em_Exposed.htm
Found this answer:
The push button "Start Button" cap cover can be easily removed with your fingers by using a fingernail (or key in FOBIK) under the bottom (6-o'clock) and pulling the button towards yourself. The FOBIK can then be inserted into the opening and used like a standard to start in the car by turning it to the right noting the switch positions.
This can be used in the case of a "key fob not detected" message or a "push button start" failure.
NOTE:
The battery in the FOBIK can be completely DEAD and the WIN ignition module will power the FOBIK when inserted.
Took the battery out of my FOB and the truck cranked. I feel better about things.............
Old Jun 16, 2011 | 01:47 AM
LU229's Avatar
LU229
The battery is cheap, try replacing that first.
Probably a CR2032 battery
Old Jun 16, 2011 | 10:47 AM
bmwbutch's Avatar
bmwbutch
Yea, that was the apparent fix. I was looking at being in the middle of nowhere with a dead battery in the Fob and no backup. This gives me a little piece of mind.
Old Jun 16, 2011 | 11:06 AM
gutty96's Avatar
gutty96
Yes, it will start if the FOB is dead. That is what the key in the FOB is for, so you can still open the doors with a dead FOB.
