How much diff fluid
Old Jun 26, 2011 | 05:26 PM
newfiebullet's Avatar
newfiebullet
Default How much diff fluid
Gettin ready to change front and rear diff oil. It shows in my manual what weight to use but not how much, can anyone tell me front and rear amounts, thanks in advance.
Old Jun 26, 2011 | 07:38 PM
oldjeep's Avatar
oldjeep
2007 is Gen 3 - you're in the wrong place
Old Jun 26, 2011 | 09:07 PM
newfiebullet
Yea gotta change my info sorry, just bought a 2009 laramie 1500, 5.7
Old Jun 26, 2011 | 09:13 PM
newfiebullet
4x4...
Old Jun 27, 2011 | 12:42 AM
Pedro Dog's Avatar
Pedro Dog
Transfer Case
NV 243 3.4 Pints 1.6 Liters
NV 246 4.0 Pints 1.9 Liters
Axles
C205FD Front Axle 56 ounces 1.6 Liters
**9.25 Rear Axle 74 ounces 2.2 Liters
**Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR® Limited Slip Additive or equivalent
Old Jun 27, 2011 | 12:43 PM
InterpunX's Avatar
InterpunX
Right on good info I'm about to do this on my truck as well. Does anyone know if there better oils than other. Is lucas oil good for gear oil?
Old Jun 27, 2011 | 02:06 PM
BoomerSooner's Avatar
BoomerSooner
I recently did both front and rear diffs. I used redline gear oil, one plus with it is you don't have to use the additive.
Old Jun 27, 2011 | 03:16 PM
Pedro Dog's Avatar
Pedro Dog
Another note when doing the pumpkins, when done, the levels on the '09 should be within these notes
Front Unit
Fill Level - From Bottom of Fill Hole 20 mm (3/4 in.) ± 3 mm (1/8 in.)
The rear unit
Fill Level - From Bottom of Fill Hole 3 mm (1/8 in.) ± 3 mm (1/8 in.)
