Installing Leveling Spacer- Ball Joint just spins
Tried to install my leveling kit but i couldnt get the upper ball joint out. It just kept spinning when i turned the nut. I tried using vise grips to hold it in place but that just ripped the boot f... And now i cant get the ball joint to tighten back up... hopefully it will be ok to drive it a short distance? I made an appointment for this friday to have a place do it... They are only charging me 200 bucks to put the front in rear in... I was out there for an hour messing with this thing and im fed up with it.
take a big pry bar and place it threw the control arm and have a friends pry down or up depending on the ball joint. it will squeeze it enought to hold it normally. if this doesnt work go get a tank of map gas from the hardwear store and heat the nut until its red that will expand it enought to let it spin faster then the ball joint.
