TSB/Keyless Entry
Old Sep 16, 2011 | 05:10 PM
JohnVI's Avatar
JohnVI
Default TSB/Keyless Entry
Hey Gang,
I know there was a very long thread on the Keyless entry and a good number of people having issues with the key fobs responding. I had two questions
1) was there ever a TSB or Update Anyone found for this that the dealership could perform..I honestly don't recall (huh) one being posted, more than just a lot of frustration (Which I completely agree with)
2) Is there a site I can go to to see open TSB's for my truck
As always thanks gang
Old Sep 20, 2011 | 04:48 PM
70GS455's Avatar
70GS455
I think the TSB is only for 2010's.
Old Sep 21, 2011 | 08:21 AM
RAMULAK's Avatar
RAMULAK
As well as the top of the 4th gen page on this site, auto md . com has a list by year for the Rams.
Old Sep 21, 2011 | 07:38 PM
hounddogg's Avatar
hounddogg
Crud gets in the fobs. I have Ford,Dodge and Chevy fobs. After a while they all get poor. I open them up,carefully wipe off battery or replace wipe off contacts and put back together. Then they work like new. Cleaning them carefully is the trick. My wife does a better job of wiping the contacts,button contacts better then me.
Old Sep 21, 2011 | 11:09 PM
Owensue's Avatar
Owensue
[QUOTE=JohnVI;2598078
As always thanks gang[/QUOTE]
you can visit https://www.dodge.com//hostb/crossbrand/owners/en/ and put your vin in the centre left to view recalls for your truck.
Old Sep 22, 2011 | 09:05 AM
kddsRam's Avatar
kddsRam
Originally Posted by hounddogg
...I open them up,carefully wipe off battery or replace wipe off contacts and put back together. Then they work like new. Cleaning them carefully is the trick. ....
That just may do the trick. I had mine replaced at dealer for not working. Well, the replacement one stopped as well. Took apart and found the 4 prongs that make contact with the battery made some sort of corrosion marks on battery. I pulled out battery, cleaned contacts, rotated the battery a bit so the contacts touched a different part of battery. Works like new again !
Old Sep 22, 2011 | 09:18 AM
hounddogg's Avatar
hounddogg
Good service advisers do this a lot before selling a fob to a customer. I've had service advisers and techs that routinely cleaned contacts and if needed installed batterys at no charge. Fixed a multitude of fobs. On GM fobs dropping them breaks the plastic fingers that hold the battery in place. Have glued a few but not for customers. They usually break again quickly.
