brake light question / issue - new cap
Old Oct 13, 2011 | 01:26 PM
Mean Joe's Avatar
Mean Joe
Default Cap third brake light wire...
I'm installing a 3rd brake light on my '09 Ram 1500 with an ARE cap. Is this the white wire you are referring to? It is under the rear of the truck by the spare tire. If I run the hot to this wire and the ground to the frame it should work right?
Thanks!
Old Oct 13, 2011 | 10:52 PM
Owensue's Avatar
Owensue
Thanks!
Yes, that's the idea. There is a ground nut on the frame a little ahead by the axle. You'll need to tap into constant power on the 7way for a dome light if you have one.
Old Oct 14, 2011 | 12:21 PM
iskybantilus's Avatar
iskybantilus
yes that is the white wire they used on my cap as well.
