Help!! warranty fix gone bad!!!!!
Old Oct 17, 2011 | 09:07 PM
HEMI_ROM's Avatar
HEMI_ROM
Originally Posted by hounddogg
Its possable a manifold issue. But I've been reading two forums almost two years and I can't remember a manifold or a gasket being replaced. Does these Hemis even have a gasket? lots of exhaust manifolds do not have one where manifold meets the head. You need to take it back,leave it overnight if needed and then cold engine you and tech,service writer see what your noise is.
I had my manifold and gasket replaced due to a broken exhaust Manifold bolt.
If the had replaced all of them int he RRT at once instead of just the broken one I took it in for, it would not have happened. They had to pull the Cyl head and send it to a machine shop because the bolt broke flush with it.
Old Oct 17, 2011 | 11:48 PM
hounddogg's Avatar
hounddogg
Mine had a cold tick almost from the get go new. Had new bolt,studs in the first 3000 miles. No issues since.
