Front alignment question
Old Nov 3, 2011 | 09:32 PM
coolatc's Avatar
coolatc
Question Front alignment question
I just removed a 2.5" leveling kit from my 2009 Laramie crew cab. I am taking it back to the shop for an alignment. Do these trucks need a 4 wheel alignment or just a front end alignment?
Also if I decide to install a set of 1/4" billet wheel spacers at a later time will that affect the alignment settings?
Old Nov 4, 2011 | 12:21 AM
LU229's Avatar
LU229
2 wheel alignment, but they`ll sell you a 4 wheel alignment job due to the fact that they have to hook up all 4 alignment heads on all 4 wheels to do the alignment properly. By doing this, it allows them to look at the tracking pattern of all 4 wheels and bring in the specs on the money (BUT, only if you have an alignment guy that knows what he`s doing that is..!)
I dont believe the 1/4inch wheel spacers will change the alignment, BUT, talk to an alignment specialist before you do that.
Old Nov 4, 2011 | 08:16 AM
oldjeep's Avatar
oldjeep
On truck with a straight axle in the rear it is called a Thrust Alignment. Used to be cheaper than a full on 4 wheel alignment.
Old Nov 10, 2011 | 10:45 PM
brettj2408's Avatar
brettj2408
Just need a front end alignment no adjustments for the rear and also wheel spacers will not effect alignment specs
Old Nov 11, 2011 | 03:15 AM
AZdave's Avatar
AZdave
Coolatc, whats the backstory with the pulling of the leveling kit? Noise, articulation, shocks, handling, tire wear? Just curious.
Old Nov 11, 2011 | 01:20 PM
coolatc's Avatar
coolatc
I uninstalled the Top Gunz Customz level kit mainly because I changed tires. I was running the 305/55/20 Nitto Terra Grappler which is an awesome tire. But I've started doing more Interstate driving and my mileage really suffered. So I went back to a stock size tire. (Cooper discovery HT Plus). Once the less aggressive tires were on there, I thought it looked better with the factory rake. So off came the kit.
I had no issues with my level kit. Just decided to go back to stock for the driving style I do. BTW I have the Nittos for sale as well as the TGC level kit, as well as some high end 1/4" spacers from Motorsports Technologies if anyone is interested? All sitting in my basement taking up room.
