2wd on 37s???
Old Nov 14, 2011 | 07:27 PM
iimario5ii's Avatar
iimario5ii
Default 2wd on 37s???
I have a 2010 ram hemi sport2x4 just ordered a 7 inch cst suspension kit with a 3 inch body lift. Will I be able to fit 20 inch xd monsters on 37"nitto trailgraplers? And will I have to change my gear ration? Or have any transmission problems in the future?
Old Nov 14, 2011 | 11:00 PM
09RuffRam's Avatar
09RuffRam
i have 37s with a 6 inch lift...my bf's are a little skinnyer tho then the nittos. as for the other info i have no idea
Old Nov 15, 2011 | 06:33 AM
BULLRAM's Avatar
BULLRAM
Let everyone know what size gear is in there now?, you will most likly need to regear with those if you want your acceleration back, I have seen 35's with that set up fit no problem, 35's fit with just my 7 on my 2WD, your speedo will be off ,so you will need a tuner to re set .
Old Nov 15, 2011 | 08:04 PM
brettj2408's Avatar
brettj2408
You can fit 37s on a 6 inch lift so ona 10 might look small but should be.fine. I would regear if going with 37s to a 4.10 or 4.56 gear ratio
Old Nov 16, 2011 | 12:10 AM
mdram43's Avatar
mdram43
might throw some slim spacers on there to be safe/ make your stance a little stabler and mean looking.
but yea your gonna need to re-gear and calibrate your speedo
