Trailer Charging Wire - Towing
So, my 2010 Dodge Ram has a 160 amp alternator, a 12 gauge charging wire,
and a 14 gauge ground wire for the 7-pin trailer connector.
I want to run my fridge on DC AND charge the battery while towing, but the factory wiring is not going to be able to handle that.
If I add parallel 10 gauge wires to the pos and ground wires, will I be covered ?
( They have the 12 gauge pos wire on a 30 amp fuse !?!?!?)
Current capacity is mainly based on wire gauge, number of conductors, and insulation type. In this instance, the 12 AWG wire can handle more than 30 amps.
What nature of RV is it that contains this DC powered reefer? Typically, the electrical option for an RV fridge is 110V AC.
Yes, the breakaway battery and the fridge are on the same wire, so it will be running the fridge (14.6 amps) AND charging the battery (amps ? yellow top Optima ).
CHILLYPOND: RV fridges run lots of ways. Mine is a typical 3-way unit and runs on 12v DC, 110v AC, or LP GAS. My camper is a little trailer bugger, but has all the goodies.
So, are you saying I really don't need to run a dedicated 12v line to do what I need?
If I was you, I'd run a new circuit, like I talked about, but if you're confident that you won't be pulling more than 30A, you'll probably be okay just using it as is.
Ironsides: Thanks for the replies.
I don't have the backup camera OR the rambox, so the only thing on that circuit will be the 7-pin 12v pos connector going to the camper. I guess I'll give it a shot and just use it. I usually start out with a charged battery , and also have hookups, so any charge current should be minimal. Seems like I should be staying below 30amps.
I did run a dedicated circuit in my old tow vehicle (Isuzu Trooper), so I could add one later if I get a wild hair.
Thx
