Old Aug 12, 2015, 01:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Four Wheel Drive Guides
Print Wikipost
4wd Low Question
Old Nov 30, 2011 | 04:07 PM
fouroheight68's Avatar
fouroheight68
Default 4wd Low Question
I am not sure if 4wd low in my 2010 ram is working correctly. When I switch from 2wd directly to 4low, the 4low light just flashes on the dash, and does not engage. When I switch from 2wd to 4lock, let the 4wd engage (4wd light on dash steady), then to 2wd, the 4wd light is on steady and the 4low light still flashes. It is in 4 wheel drive at this point, but Im not sure if it is in 4low. Should the 4low light be steady or flashing? Can I switch directly from 2wd to 4low or do I need to go to 4lock first?
Thanks
edit - Guess I need to try neutral then 4low.
Old Nov 30, 2011 | 04:55 PM
Nate769's Avatar
Nate769
I try to go into 4 before I go into 4 low. Also I try to be stopped before I do engage it. I think the manual says no more than 20km/h but I know that thats a pretty pretty big ratio difference.
Yes the 4 low will blink. If its not engaging you will get a service 4wd light
Old Nov 30, 2011 | 06:36 PM
Mikeyyy816's Avatar
Mikeyyy816
Neutral before shifting into 4lo..then the light will come on steady
Old Dec 1, 2011 | 08:47 AM
thiggins's Avatar
thiggins
STOPPED and in neutral to get to 4 low. It's VERY low, and can easily overpower your brakes.
Old Dec 1, 2011 | 09:08 AM
jayman84's Avatar
jayman84
If 4 lo is blinking then you are not in 4 lo. I have used it several times and it never blinks.
Old Dec 1, 2011 | 12:04 PM
DodgeCares's Avatar
DodgeCares
Thanks
Fouroheight,
Here is how it should work. I have highlighted each procedure as there are three different configurations based on the options of your particular vehicle. A manually shifted transfer case, electronically shifted transfer case with 4 position switch, and an electronically shifted transfer case with 5 position switch. See below. It discusses the flashing light.
Shifting Procedure – Manually Shifted Transfer
Case
2H or 4H ⇔ 4L
With the vehicle rolling at 2 to 3 mph (3 to 5 km/h), shift
the transmission into NEUTRAL. While the vehicle is
coasting at 2 to 3 mph (3 to 5 km/h), shift the transfer
case lever firmly to the desired position. Do not pause in
transfer case NEUTRAL.
NOTE:
• Pausing in transfer case NEUTRAL in vehicles
equipped with an automatic transmission may require
shutting the engine OFF to avoid gear clash while
completing the shift. If difficulty occurs, shift the
transmission into NEUTRAL, hold foot on brake, and
turn the engine OFF. Make shift to the desired mode.
• Shifting into or out of 4L is possible with the vehicle
completely stopped, however difficulty may occur due
to the mating clutch teeth not being properly aligned.
Several attempts may be required for clutch teeth
alignment and shift completion to occur. The preferred
method is with the vehicle rolling 2 to 3 mph (3 to
5 km/h). Avoid attempting to engage or disengage 4L
with the vehicle moving faster than 2 to 3 mph (3 to
5 km/h).
• Do not attempt to shift into or from 4L while the
transmission is in gear.
Electronically Shifted Transfer Case
(Four-Position Switch) –
If Equipped
This is an electronic shift transfer case and is operated by
the 4WD Control Switch (Transfer Case Switch), which is
located on the instrument panel.
2WD or 4WD LOCK⇔ 4WD LOW
NOTE: When shifting into or out of 4WD LOW some
gear noise may be heard. This noise is normal and is not
detrimental to the vehicle or occupants.
Shifting can be performed with the vehicle rolling 2 to
3 mph (3 to 5 km/h) or completely stopped. You can use
either of the following procedures:
Preferred Procedure
1. With the engine running, slow the vehicle to 2 to
3 mph (3 to 5 km/h).
2. Shift the transmission into NEUTRAL.
3. While still rolling, rotate the transfer case control
switch to the desired position.
4. After the desired position indicator light is ON (not
flashing), shift the transmission back into gear.
Alternate Procedure
1. Bring the vehicle to a complete stop.
2. With the ignition switch in the ON position and the
engine either OFF or running, shift the transmission into
NEUTRAL.
3. Rotate the transfer case control switch to the desired
position.
NOTE:
• If Steps 1 or 2 of either the Preferred or Alternate
Procedure are not satisfied prior to attempting the
shift, then the desired position indicator light will flash
continuously while the original position indicator light
is ON, until all requirements have been met.
• The ignition switch must be in the ON position for a
shift to take place and for the position indicator lights
to be operable. If the ignition switch is not in the ON
position, the shift will not take place and no position
indicator lights will be on or flashing.
(Five-Position Switch)
– If Equipped
2WD or 4WD AUTO or 4WD LOCK ⇔ 4WD LOW
3 mph (3 to 5 km/h) or completely stopped. Use either of
Preferred Procedure
Alternate Procedure
1. Bring the vehicle to complete stop.
NEUTRAL.
position.
NOTE: If Steps 1 or 2 of either the Preferred or Alternate
Procedure are not satisfied prior to attempting the shift or
if they no longer are being met while the shift attempt is
in process, the desired position indicator light will flash
continuously while the original position indicator light is
NOTE: The ignition switch must be in the ON position
for a shift to take place and for the position indicator
lights to be operable. If the ignition switch is not in the
ON position, then the shift will not take place and no
position indicator lights will be on or flashing.
Old Dec 1, 2011 | 06:34 PM
Nate769's Avatar
Nate769
Originally Posted by DodgeCares
Fouroheight,
Case
2H or 4H ⇔ 4L
NOTE:
5 km/h).
If Equipped
Preferred Procedure
Alternate Procedure
NEUTRAL.
position.
NOTE:
– If Equipped
Preferred Procedure
Alternate Procedure
NEUTRAL.
position.
Learn something new everyday...I never use 4 low but I switched to it by accident one time and thought it went into 4 low, but never really payed attention if it actually engaged or not. I managed to get out of the rim deep mud I was in so I know it went in 4...Just thought it blinked, I hereby retract my previous statement!
