Old Aug 12, 2015, 02:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
Parking assist sensors
Old Dec 6, 2011 | 01:29 PM
706jim's Avatar
706jim
Default Parking assist sensors
I have the parking assist sensors that beep in reverse when approaching a curb or parked vehicle. Recently, they seem to be dormant; never making a sound. I'm aware of the defeat switch on the dash that turns this off and I've tried it in both positions.
Anybody else have this happen?
Old Dec 6, 2011 | 03:37 PM
Mikeyyy816's Avatar
Mikeyyy816
Did any of the park assist sensor plugs fall out on the back behind the bumper? I don't have em on my truck, and I refuse to get them. But on my buddies F-150 they just plugged into the sensor behind the bumper...possibly similar set up.
Old Dec 6, 2011 | 07:19 PM
Owensue's Avatar
Owensue
The parking assist can be silences in the evic also I believe.
Old Dec 6, 2011 | 07:37 PM
tobyjohnson11's Avatar
tobyjohnson11
Yes Check the EVIC.... There are options in there.
Old Dec 6, 2011 | 07:50 PM
706jim's Avatar
706jim
I'll check that out.
Thanks.
Old Dec 7, 2011 | 12:16 AM
Nate769's Avatar
Nate769
You don't like them or just trying to stay away from them?
Yes x2 on the EVIC
Old Dec 7, 2011 | 10:17 AM
DodgeCares's Avatar
DodgeCares
Jim,
Here are the entire set of directions.
Enable/Disable ParkSense
ParkSense can be enabled and disabled with a switch
located in the switch bank of the instrument panel or
through the Customer-Programmable Features section of
the EVIC. The available choices are: OFF, Sound Only, or
Sound and Display. Refer to “Electronic Vehicle Information
Center (EVIC)/Personal Settings (Customer-
Programmable Features (SETUP)” in “Understanding
Your Instrument Panel” for further information.
When the switch is pressed to disable the system, the
instrument cluster will display the “PARK ASSIST DISABLED”
message for approximately five seconds. Refer
to “Electronic Vehicle Information Center (EVIC)” in
“Understanding Your Instrument Panel” for further information.
When the shift lever is moved to REVERSE
and the system is disabled, the EVIC will display the
“PARK ASSIST DISABLED” message for as long as the
vehicle is in REVERSE.
The switch LED will be ON when ParkSense is disabled
or defective. The switch LED will be OFF when Park-
Sense is enabled.
Service ParkSense
When the ParkSense Rear Park Assist system is malfunctioning,
the instrument cluster will actuate a single
chime, once per ignition cycle, and it will display the
“CLEAN PARK ASSIST SENSORS” message. Refer to
“Electronic Vehicle Information Center (EVIC)” in “Understanding
When the shift lever is moved to REVERSE and the
system has detected a faulted condition, the EVIC will
display the “CLEAN PARK ASSIST SENSORS” message
for as long as the vehicle is in REVERSE. Under this
condition ParkSense will not operate.
If “CLEAN PARK ASSIST SENSORS” appears in the
Electronic Vehicle Information Center (EVIC) after making
sure the rear bumper is clean and free of snow, ice,
mud, or other debris, see your authorized dealer.
Cleaning ParkSense
Clean the ParkSense sensors with water, car wash soap
and a soft cloth. Do not use rough or hard cloths. Do not
scratch or poke the sensors. Otherwise, you could damage
the sensors.
ParkSense System Usage and Precautions
NOTE:
• Ensure that the rear bumper is free of dirt and debris
to keep the ParkSense Rear Park Assist system operating
properly.
• Jackhammers, large trucks, and other vibrations could
affect the performance of the ParkSense Rear Park
Assist system.
• When you turn ParkSense off, the instrument cluster
will display “PARK ASSIST DISABLED.” Furthermore,
once you turn ParkSense off, it remains off
until you turn it on again, even if you cycle the ignition
key.
• When you move the shift lever to the REVERSE
position and ParkSense is turned off, the instrument
cluster will display “PARK ASSIST DISABLED” message
for as long as the vehicle is in reverse.
• ParkSense, when on, will MUTE the radio when it is
sounding a tone.
• If a ParkSense system malfunction occurs, a single
chime will sound once per ignition cycle. In addition,
the Electronic Vehicle Information Center (EVIC) will
display “CLEAN PARK ASSIST SENSORS” and the
LED in the ParkSense switch will illuminate. If this
message continues to appear in the Electronic Vehicle
Information Center (EVIC) after making sure the rear
bumper is clean and free of snow, ice, mud, or other
• Clean the ParkSense sensors regularly, taking care
not to scratch or damage them. The sensors must not
be covered with ice, snow, slush, mud, dirt, or debris.
Failure to do so can result in the system not working
properly. The ParkSense system might not detect an
obstacle behind the bumper, or it could provide a false
indication that an obstacle is behind the bumper.
• Objects must not be within 12 in (30 cm) from the rear
bumper while driving the vehicle. Failure to do so can
result in the system misinterpreting a close object as a
sensor problem, causing the “CLEAN PARK ASSIST
SENSORS” message to be displayed in the instrument
cluster.
Old Dec 8, 2011 | 03:36 PM
NoMoreGMsForMe's Avatar
NoMoreGMsForMe
My sensors saved my bacon and rear bumper, while backing up in parking lot when it was dark and raining my sensors alerted me of an object behind me that I had not noticed in my mirrors,that object was a hydro pole witch I surely would have hit had it not been for those sensors alerting me ,I would not have a vehicle without them,they paid for themselves in this situation.
Old Dec 8, 2011 | 05:48 PM
706jim's Avatar
706jim
Anyway, mine are working again. Maybe they always were and they are just not as sensitive to snowbanks as they are to "harder" objects.
Thanks for all of the suggestions.
Old Aug 3, 2015 | 02:41 PM
lilymcg's Avatar
lilymcg
Default help EVIC
What is EVIC? I liked through the dashboard system info and could not find anything about park assist. Mine was working fine then suddenly stopped.
Thank you
