newbie, tire question
Old Dec 10, 2011 | 08:18 PM
brewski's Avatar
brewski
Default newbie, tire question
hey guys and gals new on here,
just have a simple question: i have an 09 ram 1500 slt the stock tire size on it 275 60 r20 im not much of a tire guy and i have a new set of tires that are avaliable to me but they are 275 55 r20 in size, will they fit on my 20 inch rims properly?
Old Dec 10, 2011 | 11:24 PM
seigell's Avatar
seigell
They'll fit on the 20" rims just fine, but as 55-series, they'll be a bit wider and not quite as tall. That means better cornering grip, bit less sidewall flex to absorb pothole hits and freeway expansion joints. It also means your speedo will be slightly off - going a bit slower than speedo says...
Old Dec 10, 2011 | 11:42 PM
jayman84's Avatar
jayman84
they will be about a half and inch shorter than stock. if they are both a 275 then the width doesn't change at all.
Old Dec 11, 2011 | 12:01 AM
brewski's Avatar
brewski
ok, thanks for the input guys,
Old Dec 11, 2011 | 01:50 AM
merv's Avatar
merv
275/60r20
275 is the width of the tire in mm from the widest part of the outer sidewall to the widest part of the inner sidewall
60 is the sidewall height measured from the rim to the tread. It is a percentage of the width. So, a 60 is (275 x 0.6) 165mm
A 55 (275 x 0.55) would be 151.25mm
Old Dec 13, 2011 | 10:47 PM
DATANK1436's Avatar
DATANK1436
I went from the stock goodyear 275/60/20 in favor of some 275/55/20 hankook snow tires cuz my I only run my stock wheels in winter. They fit fine they just look more low profile and have a wider appearance although they arent just a illusion. Size wize they arent that much shorter maybe 3/4 inch. 275/55/20 also are alot easyer to find and will be cheaper
Old Dec 13, 2011 | 11:27 PM
mdram43's Avatar
mdram43
yea, the actual uninflated width size doesnt change at all. however given they are beefier, when inflated they may sit thinner than your stock one. Your tires are going to be thinner and not as tall. so your speedo is also going to be off
