How to run wire from bed to cab ?
Old Dec 11, 2011 | 07:07 PM
jon9's Avatar
jon9
Default How to run wire from bed to cab ?
I have a 2010 RAM Big Horn. How do I run a wire from the bed to the cab to install a switch for a back up camera? Are there any factory installed wiring pathways?
Old Dec 11, 2011 | 08:10 PM
Mikeyyy816's Avatar
Mikeyyy816
Check out my thread I posted awhile back....I wired in some LED lights and ran a switch into the cab of my truck. You'll see in the firewall the nipple I ran the wires through. Cut the tip off, it's meant for wire runs.
Old Dec 12, 2011 | 02:24 AM
mdram43's Avatar
mdram43
theres also one right by the steering column
Old Dec 12, 2011 | 04:05 AM
Xdcinc's Avatar
Xdcinc
Do you have a stick or automatic? If you have a automatic right next to steering column there is a black plastic piece that is a cover for the clutch (if it was a stick) works great and pretty easy to get to. I ran from there to the back bumper and it was cake took me like 20 mins and most of that was spent looking for the zip ties LOL.
Old Dec 12, 2011 | 09:07 AM
rolltidehemi's Avatar
rolltidehemi
lets us know how the switch works, was thinking about adding an additonal hot to my OEM to turn it on when I wanted to to bypass the reverse on only feature.
Old Dec 12, 2011 | 11:52 AM
Mikeyyy816's Avatar
Mikeyyy816
My bad bro....I told you to look at my post about how I did it...and I never posted the link haha...
Scroll down once you get to the page and you'll see my pictures. Enjoy..
https://dodgeforum.com/forum/4th-gen...-lighting.html
Old Dec 12, 2011 | 02:48 PM
jon9's Avatar
jon9
Default Thanks will have a look
Yeah, I installed a Peak Electronics back-up cam connected to a 12V, 25ah AGM battery to power the cam. That way it's on all the time instead of just in reverse. The wire will go to the radio transmitter so I can turn it off, as to not drain the battery!
Old Dec 12, 2011 | 07:54 PM
BigBlueEdge's Avatar
BigBlueEdge
Look for instructions on installing a power tailgate lock module. You should be able to find plenty of instructions and tips on running wires from the cab or engine compartment from those. Check out the Mopar kit, 3rd party packages, and some posts on this forum about it. Alternatively, check out instructions for the Mopar bed lighting kit. I know that kit requires wires run from inside the cab.
Rob
Old Dec 12, 2011 | 10:32 PM
Mikeyyy816's Avatar
Mikeyyy816
Rob
Hey Rob, where have you been, been awhile since I've see yah post on here. Like you said, I used that Mopar bed light kit to get some ideas on how to route my wiring.
Old Dec 17, 2011 | 11:58 AM
BigBlueEdge
Been pretty busy with life the last couple months so I haven't spent much time on the forum. I think things may be evening out finally though. :-)
For the OP, did you get your wiring run successfully?
Rob
