Why two rows of spark plugs?
Old Dec 12, 2011 | 06:55 PM
LTRam1500's Avatar
LTRam1500
Default Why two rows of spark plugs?
I have the 4.7L in a 2009 Dodge 1500. Can someone please explain the benefits of having 2 rows of spark plugs?
Also I noticed in the manual that at 48k miles I am suppose to replace the top row. Then at 96k I am suppose to replace the top and side row. Why is this? Maybe it's a part of the first question but why should the top row spark plugs be replaced 2x as often as the side row?
Old Dec 13, 2011 | 12:09 AM
LU229's Avatar
LU229
The extra row of plugs burns off any excess left over fuel vapors in the combustion chambers
Old Dec 13, 2011 | 06:30 AM
ripplek's Avatar
ripplek
From allpar.com---
Cryptojoe” wrote: “The extra plug fires during the power stroke to more fully burn the hydrocarbons. ... the second ignition allows additional power in the down stroke while lowering the need for restrictive catalyst plates in the converter.
“In the 1980s Japanese manufacturers reduced unburned hydrocarbons by placing spark plugs either in the exhaust pipe (which fired with every piston ignition) or in the exhaust manifold (which fired each time their corresponding cylinder fired). Chrysler morphed this idea to include dual fired plugs on each cylinder, which allows the firing to take place closer to top dead center, and then again when the piston is on the back side of the power stroke.”
Patrick added: “This [also reduces] NOx and ozone. Full combustion results in heat, water, and carbon dioxide. NOx emissions are only significant during incomplete or partial combustion, due to the lack of available oxygen, high temperatures, and various chemical reactions. That's why catalytic converters have been standard on cars for the past 3 decades. The extra set of spark plugs on the HEMI and on previous engines are designed to reduce emissions before a catalyst is needed. They add some horsepower, but not very much.”
Old Dec 13, 2011 | 09:42 AM
LTRam1500's Avatar
LTRam1500
Thanks everyone! So from putting the information you folks enlightened me with plus the maintenance schedule I can 99% accurately say that the plugs on the "top bank" are the spark plugs used to ignite the air/fuel to drive the cylinder down and why they need to be changed at 48k miles. The side or exhaust bank plugs are exactly that and just clean up the exhaust.
Maybe this has been answered somewhere else in the forum, but reading instructions how to change these, it is really that tedious? I thought it would be as simple as remove cap, loosen/remove plug, install new and tighten. What's all this about coils and everything?
Old Dec 13, 2011 | 11:04 AM
LU229's Avatar
LU229
Originally Posted by ripplek
From allpar.com---
yeah pretty much what i answerd with, but alot less words
