2011 Ram 5.7L stalling at stops.
Old Dec 23, 2011 | 09:29 AM
CANTDODGEITRAMIT's Avatar
CANTDODGEITRAMIT
Default 2011 Ram 5.7L stalling at stops.
This is the first somewhat serious problem that I've ever had with a dodge and it's kind of concerning.
A little history:
Unfortunitley a few months ago I got into a bit of a front end fender bender (my bad). It was mostly front end body work and replacement of radiators. So, nothing really to do with the engine or any of the drive train components.
So, I just got the truck back from the dealership this week (the accident was in early sept) and now I have a sticking lifter and the truck stalls when coming to a stop. It's almost like the trans isn't disengaging which causing the engine to stall out. I throw it in to neutral and fire it up lke nothing happened. Until the next random stall at a stop.
So, has anyone else experienced these problems with their 4th gens.
Oh yeah, the truck only has 12600km on it, if that adds any value.
Old Dec 23, 2011 | 10:26 AM
oldjeep's Avatar
oldjeep
If they replaced the tranny cooler then it is certainly possible that they let some crap get into one of the cooler lines that is plugging up a passage in the valve body.
Old Dec 23, 2011 | 10:27 AM
plumcrazy73's Avatar
plumcrazy73
sounds like you need to take it back to them and let them have at it again with the truck
Old Dec 23, 2011 | 10:37 AM
InterpunX's Avatar
InterpunX
That used to happen to my truck when it was first new. I ended up having a bad torque converter they had to change (not saying that's the problem but mine stopped doing after the repair) the torque converter is not unlocking creating ur truck to stall.
Just a thought
Old Dec 23, 2011 | 10:57 AM
CANTDODGEITRAMIT
Interpunx,
When ur truck would stall out, did it kind of clunk to a stop?
Old Dec 23, 2011 | 11:23 AM
InterpunX's Avatar
InterpunX
Not really no clunky I guess but it was like it still in gear. I would slow down to a stop and it would lightly shake and just stall like as if driving a standard truck and not pressing on the clutch when stopping
Old Dec 23, 2011 | 11:46 AM
CANTDODGEITRAMIT
OK, thats exactly what my truck is doing. I'm going to do some searching around to see if anyone else has had a similar torque convert problem with their 4th gens.
Thanks guys for your input. I'll be sure to check back in on this thread to see if anyone else has some input.
Old Dec 23, 2011 | 01:03 PM
Nate769's Avatar
Nate769
TAKE IT TO THE DEALERSHIP! You only have just over 12K on your truck with lots of warranty left. Let them deal with it! If it means having it in the dealership that much longer so be it. If the issue happens to be something that is gonna cause bigger problems, like something internally finally giving out. Now you could be in the need of a new engine, thats gonna take longer to replace then to replace something else that could be "minor"
I'm not trying to steer anyone away from finding out what the issue is, lets continue seeing if we can find the issue before the dealership does...Just saying to the OP to take it in, don't mess around with a practically brand new truck!
Old Dec 23, 2011 | 01:20 PM
LU229's Avatar
LU229
A torque convertor that does not unlock properly, WILL destroy a transmission in a very short time.
Not to mention, it isnt doing the rest of the driveline any good either.
(ie: transfer case, ring & pinion[s], u-joints, cv axle`s)
POWER SEDAN's Avatar
POWER SEDAN
My fathers Dakota had simular issue, it would shake when coming to a stop almost stall, or clunk "loud," they ended up replacing his torque coverter as well.
