What size tires on a 2012 1500?
Old Jan 22, 2012 | 02:05 AM
slackjaw71's Avatar
slackjaw71
Default What size tires on a 2012 1500?
Looking at a 2012 1500 4x4 and they look a little low in the front. Will my 285/70/17's fit without any mods or turning keys, etc...?
Looking at downsizing from an '08 2500 long bed 4x4 to a 1/2 ton short bed. Don't need a heavy duty truck since I bought a motorhome.
Btw, any clue what it would cost to add a 4" suspension lift to the same 2012 1/2 ton? The truck seems really low compared to my 3/4 ton.
Old Jan 22, 2012 | 04:22 PM
schmeadley's Avatar
schmeadley
The 285/70/17 may fit as mine came through stock with 275/70/17 and was also low in the front and the 285 s are just a tad bigger. The only thing you may want to think about is the sidewall rating if it's a Load rating "E" that small light truck is gonna ride hard. Just sayin.
Old Jan 22, 2012 | 06:15 PM
frogslinger's Avatar
frogslinger
E range will be fine...
there are no keys to turn on a 2012
Old Jan 22, 2012 | 07:15 PM
Patsfan's Avatar
Patsfan
Should be fine, I believe that is the same diameter as the stock 20s.
Old Jan 23, 2012 | 09:53 AM
slackjaw71's Avatar
slackjaw71
How do you level the front end on a 2012?
Old Jan 23, 2012 | 09:44 PM
Patsfan's Avatar
Patsfan
I don't think the 2012s are any different to level than other 1500 4th gens. You have to remove the strut and install a spacer. No torsion keys.
http://www.tuffcountry.com/dodge-ram-leveling-kits.html
Old Jan 24, 2012 | 06:08 PM
frogslinger
In order of sexiness:
Icon coilovers
Bilstein 5100 struts with ride height adjustment
Spacer (be sure not to go over any large holes as you may dent your struts and hyper-extend your joints)
