Need Torque Settings Cab/Frame bolts
Old Jan 26, 2012 | 08:31 PM
Capn Preshoot's Avatar
Capn Preshoot
Default Need Torque Settings Cab/Frame bolts
I'm about to install a set of Westin Nerf Bars and it occrred to me that the cab-to-frame bolts have specific torque settings (so as not to distort the door alignment). Does anyone know what the torque value should be? (2010 Crew Cab 1500)
Thanks in advance!
Old Jan 26, 2012 | 11:59 PM
LU229's Avatar
LU229
Thanks in advance!
Not a good practice to rely on what people will tell you,
go to a dodge dealer bodyshop and have them look up the correct spec and precedure in the bodyshop manual.
Old Jan 27, 2012 | 12:37 AM
CHILLYPOND's Avatar
CHILLYPOND
From the Service Manual. There's a caution too:
CAUTION: ** Whenever a body isolator bolts requires servicing or tightening, it is necessary to remove the bolt and install new thread locker compound to the threads.
Old Jan 27, 2012 | 07:46 AM
TurboGPZ's Avatar
TurboGPZ
Are you using the same bolts or does the kit have their own bolts???? Are they the same grade???
Old Jan 27, 2012 | 09:14 AM
Capn Preshoot
Thanks for the attachment !!!!! (and the tip)
I'll pick up some LokTite tonight.
