rear end alignment after 4 inch lift?
I am getting conflicting info from two different dealers service departments, one says you only need to align the front end of the truck and the other says that the front and back wheels have alignment adjustments that need to be done after the lift of a 4th gen.
What say you, the all knowing experience group on this forum?
And I'm not curbing him either!
As far as I know, correct me if I'm wrong, but any place you got to to have an alignment done is going to check all for anyway. At least that's what I've seen done at every shop I've either seen/had one done at.
Or to put it even more simply... you cannot align the rear end, you can just make sure the truck is not crabbing.
You confirmed my knowledge and suspicions, thanks! I talked to the on line help at RCX and the guy said as long as the track bar is installed properly, well I've looked and don't see any adjustments to throw it off, simple set up in my book, I was scratching my head with the dealer on this one, 59 for the front and a 100 for both, really!
Was gonna just do the front anyway.
