Installing aftermarket backup camera
Old Feb 18, 2012 | 01:51 PM
djf48's Avatar
djf48
Default Installing aftermarket backup camera
I have a 2011 Dodge 2500 truck with a mygig radio installed. I bought a aftermarket backup camera for it. Now I'm trying to figure out how to run the wire through the firewall so that I can run it to the back of the truck. I've looked around to see where I could string the wire through but I'm not sure of the best place to do it, any suggestions? Thanks
Old Feb 18, 2012 | 02:17 PM
rdculus's Avatar
rdculus
28. Cut the end off the dash panel grommet nipple (1)
hanging off the bottom side of the body harness near
the brake booster.
NOTE: Ensure when routing the wire not to damage
the wire terminals.
29. Route the backup camera harness through the dash
panel grommet nipple, except for the WT/LG and BK
wire.
30. Apply Mopar® RTV 82300234 around the grommet
nipple.
Old Feb 18, 2012 | 03:29 PM
djf48's Avatar
djf48
My RCA plug won't fit through the #1 hole... is that #2 for cutting a hole in the rubber?
Old Feb 18, 2012 | 06:03 PM
rdculus's Avatar
rdculus
No. If you have an automatic you should cut the plastic cover where the clutch slave cylinder would go through
Old Feb 18, 2012 | 06:57 PM
djf48's Avatar
djf48
Worked great, thank you!
