How do you tell if MDS is working
Old Feb 22, 2012 | 09:04 PM
steelhead77's Avatar
steelhead77
The only thing not stock on it is the drop in k&n filter. Right now its running on winter gas so it might affect it.
Old Feb 23, 2012 | 01:07 AM
Owensue's Avatar
Owensue
Are you sure that's not 12L/100km? Which works out to over 20mpg
I read on the display at 105km/h 24gph (switched to imperial and reset miliage) for a short highway drive.
16L/100km is prox 20mpg
Just want to be sure your seeing what your seeing.
Old Feb 23, 2012 | 06:55 AM
2011BlackRam's Avatar
2011BlackRam
WOW! My old pig weighs in at 7000 lbs., is pre-MDS and I get about 13 average and usually hit low 16s on trips...
Yeah, tell me about it. I can pull down 18-19 on the highway, but once I hit the city it drops to 10. Best case is city driving without much stopping I can get 13. But there is a ton or traffic here, so its usually stop and go at all hours with multiple stop lights per mile.
Old Feb 23, 2012 | 07:23 AM
steelhead77
Currently my readout is set for L/100KM and it reads 18.3L/100KM. When I originally posted I had it in MPG.
Old Feb 23, 2012 | 08:15 AM
gutty96's Avatar
gutty96
You are close with 12l/100kms being approx 20mpg, but way off with the 16L/100km.
15L/100km is around 15.5mpg, so go from there. IF you are using 1 more litre to drive the same 100kms, you are get LESS mpg. 16L/100kms is more like 14.5mpg.
Old Feb 23, 2012 | 08:34 AM
Owensue's Avatar
Owensue
Yea, I went the wrong way with that.
I didn't recall when I wrote my reply but yes 15l is about 15.5 g.
Old Feb 23, 2012 | 09:54 AM
JonathanA's Avatar
JonathanA
http://tdiclub.com/misc/conversions.html
Old Feb 23, 2012 | 04:25 PM
CarGuyOhio's Avatar
CarGuyOhio
1. What weight oil do you have in it?
2. Where go you live, what temp is it there?
3. Mds will kick in if a number of things are true, I can actually see my rpms jump 50 when it kicks in.
Old Feb 23, 2012 | 05:11 PM
jawsdc's Avatar
jawsdc
definitely check the oil viscosity; anything other than 5w-20 supposedly will disable the MDS.
that alone should not give you MPGs in the ten range though.
Old Feb 23, 2012 | 05:30 PM
oldjeep's Avatar
oldjeep
Originally Posted by jawsdc
definitely check the oil viscosity; anything other than 5w-30 supposedly will disable the MDS.
Supposed to be 5w-20
