In need of opinions and knowledge!!! PLEASE
Ive got a 2011 Ram 1500 Sport. It goes in on friday to get a 2.5 read lift leveling kit installed. thats the easy part. ive spent the last 5 hours reading everyones post about tires but still have yet to decide on what size to get. i understand i can fit a 35s under it but i dont understand all of the numbers with width. i would also be ok with running 33s. im looking for an aggressive look but do not want to run spacers. and i am pretty dead set on the nitto terra grapplers. please help a new guy out with pictures or anything. it would be greatly appreciated!!!
I am sure if you use stock wheels with 12.5 wide tires you will at least need a 1/4" spacer, if not more. If you get after market wheels you should be good to go with -12 offset on a 9" wide rim. you might want to look at the 295/65 size its 11.5" wide.
I have a sport also, I have a 2.5 level thats going in it, I plan on 325/65/18 with a 18x9.5 rim -19 offset should give me about 3/4 from my uca which is plenty. I will need aftermarket flares cause it'll stick out an inch and a half.
