Old Aug 14, 2015, 02:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
Dirty Brake Fluid
Old Mar 11, 2012 | 09:07 AM
LU229's Avatar
LU229
Originally Posted by dirtydog
Ever wonder why people get "stuck calipers" or leaking seals on their calipers, or their brake lines rusted from the inside out. It's because they never flush out their old brake fluid. It's corrosive!
I find it funny how guys will change to drilled/slotted rotors an pay $100 for specialized pads and then never flush out their old brake fluid that probably has 10% moisture by volume and causes the brakes to be spongy and even more spongy when they get hot....doh..
When a shop flushes your brakes, they hook up a vacuum canister to your master cylinder. I wouldn't allow them to do the old pump flush by cracking your bleeders to do a manual pump. Your master cylinder rod only gets a small portion of it used. There is generally a light rust mark where it doesn't get fully pumped(pressure keeps the pedal from going to the floor) so when you pump the pedal to the floor, your surpasssing the point of normalcy and entering light rust territory. The rust will wear on your seal and cause internal leaking. Gotta be very careful to not pump to the floor when you do a manual flush! 70%max! I do the manual pump, but I know what I'm doing and take care because it's my car, and not just another car that comes through a place I work at. I like to put a 2x4 under the pedal to prevent overpumping.
Brake fluid: DOT3 is corrosive, DOT5 is not. Just thought i`d point that out.
Old Mar 11, 2012 | 10:36 AM
oldjeep's Avatar
oldjeep
You're not supposed to use DOT 5 in an ABS system.
Old Mar 12, 2012 | 12:11 AM
LU229's Avatar
LU229
My bad, sorry, i should have said DOT5.1 (brain fade, i forgot to add the .1 to it)
The DOT5.1 is the one that is compatable with ABS brake systems, plain ole DOT5 is not.
For those that need to see written proof rather than take my word for it:
http://www.federalmogul.com/en/After...ngBrakeFluids/
Old Mar 12, 2012 | 07:09 AM
oldjeep's Avatar
oldjeep
OK, but 5 (Silicone) is the only one that does not absorb water. 5.1 is very similiar to DOT 4. The only real advantage that 5.1 has is that its boiling point is similiar to DOT 5 - really only a big deal in race cars and motor cycles.
Old Mar 12, 2012 | 10:47 AM
LU229's Avatar
LU229
Where i live, low boiling point is a problem. (alot of mountains) Thats exactly why i use DOT5.1 in my ABS vehicles, due to its higher boiling point. All my motorcycles have DOT 5 in them. The last thing you want, is your brake fluid to boil when you`re coming down the mountains. Whenever i buy a new vehicle, the first thing i change out is the factory brake pads to alot higher quality, then i flush out the factory brake fluids and replace it with DOT 5, and if i have ABS, they get DOT 5.1
Just a side note...
If you are using DOT 5 (silicone) it will be a purple color.
The color of it tells you if you have DOT 5 or DOT 5.1
Old Mar 12, 2012 | 11:06 AM
oldjeep's Avatar
oldjeep
Just a side note...
The mushy pedal feel is also a good indication you are running DOT 5. One of the reasons that it never really caught on is that DOT 5 is somewhat compressable.
Old Mar 12, 2012 | 11:10 AM
oldjeep's Avatar
oldjeep
OUt of curiosity, what are you using to flush the DOT 3/4 out of the system before replacing with DOT 5?
Old Mar 12, 2012 | 11:18 AM
LU229's Avatar
LU229
I agree...! I think it may be due to the reason that DOT 5 is thicker (???)
Old Mar 12, 2012 | 11:19 AM
LU229's Avatar
LU229
Using a snap-on vacuum bleeder. I flush the DOT 3/4 fluid out with brake-kleen
Old Mar 12, 2012 | 06:06 PM
72combo's Avatar
72combo
I am not doing this job at all, first going tomorrow to brake shop to get moisture tested and then if it is bad get their price, dealer wants a hundred bucks including fluid so they might just get the job depending on what the brake shop says.
