37" tire and bevel
Old Mar 13, 2012 | 05:10 PM
pieracc87's Avatar
pieracc87
Default 37" tire and bevel
Hi guys,
Finally i decided to install this "kit" on my 2010 dodge ram;
6" lift rough country - wheel brp 94r with 37x12.5x18
BUT i have a question, with this kit should i change the bevel?
Sorry for my not good english...
Old Mar 13, 2012 | 06:09 PM
AZdave's Avatar
AZdave
By bevel, do you mean the angle at which your front tires sit resting on the ground? If so, yes, you will need to perform a wheel alignment.
Old Mar 14, 2012 | 04:33 AM
pieracc87's Avatar
pieracc87
Exclamation
hi dave, sorry but i wrong the title, when i speak about bevel i think " GEAR RATIO " ....
i don't know which gear ratio is installed on my truck, and i ask if i change tire size from 275/60/20 to 37x12.5x20 i have to change the gear ratio???
Old Mar 14, 2012 | 02:43 PM
AZdave's Avatar
AZdave
Lots of opinions and threads on it, 4.56, etc.
Here's a thread with some opinions https://dodgeforum.com/forum/4th-gen...0-swap-qs.html
Old Mar 14, 2012 | 06:31 PM
InterpunX's Avatar
InterpunX
With the 37" tires i would suggest 4.56 gears, you will not regret it.
Old Mar 18, 2012 | 11:07 AM
schmat's Avatar
schmat
What is the advantage to changing the gears to 4.56s and are you changing gears only in the rear end.
What is the cost to change gears?
Rob
