I just joined the TPMS fail group.
Old Mar 31, 2012 | 06:42 PM
RAMULAK's Avatar
RAMULAK
Default I just joined the TPMS fail group.
Been driving the truck this week and the tire warning light would come on then go out as I drove. Been like that all week. came out this morning and the front right side was pretty low. Pumped it up and drove to work. Driving home, the light came back on. Washed the truck and went to put more air in and I could hear it hissing. Coming from the valve stem nut where it contacts the rim.....Great! Off to Dodge to get it fixed now. I am going in for heart surgery next week and did not need my truck going flat and sitting like that for 6 weeks......Ugh!
Check your TPMS stems for corrosion.
Old Apr 1, 2012 | 12:15 AM
Cmerritt84's Avatar
Cmerritt84
I have no sensors in mine. Running 3rd gen flower petals. Also have tpms disabled with my Superchips.
Old Apr 1, 2012 | 10:44 AM
LU229's Avatar
LU229
Anytime a metal part is used on a rim with these valve stems today, it is always good to have a spray bottle with some soapy water kickin around to check them occasionally. May just catch a really small leak in time and get it fixed before it turns into a nightmare... especially at a time like this with you ramulak, being that you`re going into the hospital and will be moving slowly for awhile. Best of luck on the surgery my good friend, my thoughts are with you, hope you`re back up an runnin very soon budd.
Old Apr 1, 2012 | 10:48 AM
HammerZ71's Avatar
HammerZ71
Wow! I just had the first one fail on my '02 Grand Cherokee - that's after like 11 years and 104,000 miles and it don't leak, just doesn't give a reading anymore.
I've never had a leak on a tire from one - yet anyway...
Old Apr 1, 2012 | 11:06 AM
oldjeep's Avatar
oldjeep
To the OP - you still running the original (stock) tires?
Old Apr 1, 2012 | 01:17 PM
1500TRX's Avatar
1500TRX
I ended up getting the rebuild kit for about $3 at autozone and took it up to discount tire where I bought the last set of tires for the truck and they installed it, remounted and balanced the tire for free.
Old Apr 1, 2012 | 01:30 PM
oldjeep's Avatar
oldjeep
They should have done that when they replaced the tires - didn't they? There is a kit that is supposed to be replaced every time the TPMS is removed from the rim - new nut and o-ring.
Old Apr 1, 2012 | 03:06 PM
RAMULAK's Avatar
RAMULAK
No. I got some Michelin LTX M/S2 tires put on.....at Sears.
So I highly doubt they installed a new gasket kit at all. I will pick up a kit or two and bring it back to Sears and have them install it.
I did get the hazard plan when I bought them, which comes with free balancing/rotation etc. I need to rotate the tires now that winter is over anyways.
I'll have to check the bill to see if there was any kit to be installed.
Old Apr 1, 2012 | 03:11 PM
oldjeep's Avatar
oldjeep
They were $7 at the firestone dealer that put on my Destination A/T's.
