hella light wiring question
Old Apr 24, 2012 | 12:47 AM
newram2010's Avatar
newram2010
Default hella light wiring question
I picked up a smittybilt light bar and 2 sets of hella 500 black magic lights... and im definitly no electrician haha so help me out here please.
for those of you who have put lights on the front of your truck.. where did you ground each individual light???
from what i understand the red wire goes to the + post on the batt or on the fuse box
- the black goes to the black wires on the 2 lights
-the yellow runs into the cab plugged into the switch(which of the 3 prongs does it go on????)
- the short blue one is for the ground
- the green one goes from the switch inside the cab to the headlights... where did you guys hook into with this wire?
correct me if im wrong with anything here.. any info would be awesome! thanks in advance everyone
Old Apr 24, 2012 | 11:45 AM
newmexicoram's Avatar
newmexicoram
Perhaps a member will chime in. I'm NO electrican either so...I paid to have it done.
Old Apr 24, 2012 | 12:24 PM
InterpunX's Avatar
InterpunX
I'm no electrician either but here's a few pictures that might help you. I would recommend putting a relay to power your lights.
Here's a picture for how to wire without a relay,
And this is for wiring with a relay
As far as your switch goes it should say acc on one prong, that would be to you lights. Then the other 2 are probably + and -. Just make sure you have a fuse with your +. If you put a relay on the wire from the acc on the switch ,it will go to #1 on the relay, or you could just tap into your highbeams wire to activate your relay which would turn on your hellas. It's kind of a flu explanation but i'm just waking up here hahaha. Also you can ground your lights directly on the frame somewhere using a self tapping screw.
If you have 4 lights i would recommend putting 2 relays to your switch, i found another picture that might help you out, just ignore the top relay and the red wire since you would have a 2 way switch.
Old Apr 24, 2012 | 01:37 PM
Nate769's Avatar
Nate769
Yup those diagrams cover it pretty good. There are always soo many different ways to wire, but this is probably the easiest for you to understand. I would also recommend putting a relay in for your lights as well. UNLESS the switch you bought is rated for the full amps of each of the lights, it will say so on the switch.
These diagrams say to ground to the battery as well, but I would just do as Interpun said, and just a self tapper to the frame. This way its a direct ground, and has less connections on the battery head...
Old Apr 25, 2012 | 08:22 AM
newram2010's Avatar
newram2010
Awesome guys thanks alot.., i ended up grttin it yesterday morning but it would have saved me a good amount of time to have those diagrams lol thanks a bunch
Old Apr 26, 2012 | 03:17 PM
Nate769's Avatar
Nate769
how did you end up doing it?
Old Apr 28, 2012 | 07:11 PM
newram2010's Avatar
newram2010
Instead ofrunning the (green) wire thats suppose to go to the highbeam hot wire i put it on the positive on the fusebox.... And i had the switch hooked up wrong to start that didnt help lol
I extended the ground wires to the bumpers bolts... If ur doing it urself pm me n ill give u some more detail as im on my phone right now n dont type so well with just my thumb lol
