Brake pads for RAM 1500
Old May 16, 2012 | 03:15 PM
laboy's Avatar
laboy
Default Brake pads for RAM 1500
Hi guys!
I have 10' RAM 1500 Quad Cab Sport and it's about 30K miles.
I can hear some squeaking noise when breaking, looks like I need new pads.
There is so many brands online, what should I get? I need inexpensive and good pads. Thanks an advance!
Old May 16, 2012 | 05:38 PM
oldjeep's Avatar
oldjeep
Take a wheel off and check them, chances are that there is just something in the slot or the pads are vibrating in the caliper. I replaced mine at about 30K because I had a squeak and it turned out that they were only about 25% worn.
Old May 16, 2012 | 06:17 PM
POWER SEDAN's Avatar
POWER SEDAN
30k does seem kinda early, I'd inspect first as well.
A good quality pad that won't break the bank, for me has been Centric Posi Quiets pads. Look under centricparts.com, or check out r1concepts.com.
I believe we also have a supporting vendor here that specializes with brake parts/pads as well. Chances are they'll chime in, however I'm not familiar with their products.
Old May 16, 2012 | 06:38 PM
hounddogg's Avatar
hounddogg
Mine have abut 75% left at 36k. Never a beep from them.
Old May 16, 2012 | 06:59 PM
laboy's Avatar
laboy
Thanks, good info. Will inspect them first.
dirtydog's Avatar
dirtydog
Moderate User
Hilly areas tend to be more harsh on brake pad life. LA and surrounding areas are kinda hilly.
BrakeMotive is a Sponsor of the site and they sell complete F&R sets of Perf. rotors w/ceramic pads HERE
For just pads on the front, I'd go with Wanger Thermo-quiets installed with Caliper grease. Those pads are online tend to be much cheaper.
Caliper rtv/grease stops any squeel. Squeel is pads vibrating between caliper and rotor. Use with any new installation.
