Old Aug 13, 2015, 05:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
How to remove overhead console?
Old May 27, 2012 | 07:20 PM
Arachnyd's Avatar
Arachnyd
Default How to remove overhead console?
I was searching, and I found how to remove the map lights, but how do you remove the entire console? How do you access the screws and stuff or do you have to take off the entire headliner?
Thanks!
Old May 27, 2012 | 10:52 PM
Mikeyyy816's Avatar
Mikeyyy816
No don't pull the headliner out... Just use a trim tool or a flat head with a rag wrapped around it and pop it out and pull it out. Then grasp the bulb n. Pull it out
Old May 28, 2012 | 09:47 AM
Arachnyd's Avatar
Arachnyd
So there are no screws holding in the overhead console? Any idea where to pop it out at? (back, sides front, or does it not matter??) I just went down there and I had a lot of trouble because the headliner is soft and just compresses when I try to pry on it, but if I could figure out where the clips are i my be able to compress those and pull it out? thanks!
Old May 28, 2012 | 09:52 AM
Arachnyd's Avatar
Arachnyd
OK I finally found the explanation at https://dodgeforum.com/forum/4th-gen...e-removal.html
Thanks for your help!
Old May 28, 2012 | 11:53 AM
Mikeyyy816's Avatar
Mikeyyy816
No problem.. I pried near the map lights first then I popped around.
