Easy exit seat function
Old Jul 6, 2012 | 09:05 PM
rolltidehemi's Avatar
rolltidehemi
Default Easy exit seat function
Have this enabled on 09 evic an all of a sudden it's not working, anyone else have/had this issue, also every now and then if I hit door unlock on remote more than a couple times windows will come down a third or all the way! On above I have removed negative battery and disabled/enabled in evic still no fix, all other seat functions work, plugs are in place!
Old Jul 6, 2012 | 09:47 PM
2010 TRX4's Avatar
2010 TRX4
When your doors are unlocked if you hold unlock on the remote the windows will come down. They will not however go back up remotely. This feature is in the owners manual, and there is a huge thread on the 2nd page on this website. As far as the easy exit seat function I have an EVIC but not that specific feature.
Old Jul 7, 2012 | 07:15 PM
rolltidehemi
Found on a jeep forum that if you turn car on and cycle seat forward and back so seat learns new limits it should correct and it worked, only other problem on going is the track pops when moving towards the rear position and towards the forward position, had this for a while, cant be good, I know others had it, any fixes?
Old Jul 8, 2012 | 04:31 PM
mcs's Avatar
mcs
Mine also stopped working for no obvious reason.
Old Jul 8, 2012 | 09:41 PM
mcs's Avatar
mcs
Easy exit seat function working again.Thanks to rolltidehemi advice.Seat had to learn new limits.
Old Aug 2, 2013 | 09:41 AM
jason.newberry's Avatar
jason.newberry
Default ???
My wife's '11 Durango has this option and we love it. But I can't find it in the EVIC of my '13 Ram 1500 Laramie?
Old Aug 4, 2013 | 04:41 PM
Dale_K's Avatar
Dale_K
I had this feature in a 300C and fairly often I'd need to run the seat all the way back & forth to retrain it. I think my power tilt wheel used to need it too.
Old Aug 6, 2013 | 11:50 AM
DodgeCACares's Avatar
DodgeCACares
Jason,
Welcome to the Dodge Forum!
Was your Ram equipped with the Easy Exit Seat feature from factory? If you would like me to confirm this please PM me your VIN# and I'd be happy to help.
