2012 Door Panel Removal ??
Just wanted to run this past the experts before I break something. Going to tint the windows and want to pull the door panel off to get the tint way down inside the door.
I see the "fake" torx screws and the plastic expansion parts they pug into and got them out. Looks like a hidden screw under the interior door open handle. What other hidden screws or clips are there? Most every panel I have ever taken apart before had some sort of spring clip that either pulled straight out or lifted up, anything like that?
I'm sure this is a simple solution just didn't want to start pulling on things and learn the hard way!!
Thanks
Thanks
On a 2009 - which I assume is the same.
You pop out the power windows switch panel.
Remove the screw behind the door lever
The screws on the bottom you unscrew and remove - then the plastic clips will come out.
Then you just push the panel up
Got it thanks !!
I would have busted something for sure if I didn't ask.
Once I removed the torx screws, Phillips and the triangular piece at the front it was still attached. Like you guys said "LIFT IT UP" and it unhooks from the back. Had I pulled as per usual I would have broken a couple of those tabs for sure!
Once I saw how it was held on I wasn't sure how the heck I was going to align all those tabs and get the panel back on?? Got lucky and it lined right up :-)
Thanks again for the tips
