Old Aug 17, 2015, 12:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Check Engine light ( low oil pressure code)
Old Aug 2, 2012 | 05:28 PM
Helmster's Avatar
Helmster
Default Check Engine light ( low oil pressure code)
2009 5.7 Hemi, check engine light came on took it in needed oil change anyways, mechanic said code for low oil pressure... but cant figure out why yet.. anyone else have this happen?
Old Aug 2, 2012 | 10:16 PM
POWER SEDAN's Avatar
POWER SEDAN
Could be the sending unit. Did the mechanic check the oil preasure while you were there for service anyways? If its a bad oil pump, that could be catastrophic "soon" if you're still currently operating/driving your truck!
Old Aug 3, 2012 | 07:50 AM
12Sport's Avatar
12Sport
+1 on that. I'm surprised you got a check engine light on low oil pressure instead of the low oil pressure warning light illuminating or your oil pressure gauge not showing low pressure.
Old Aug 3, 2012 | 08:37 AM
thiggins's Avatar
thiggins
Ahhh !!! That's scary.
Old Aug 3, 2012 | 10:38 AM
POWER SEDAN
That's why I'm thinking it maybe a faulty sending unit, which can still allow somewhat oil preasure. I still would NOT be operating your truck until 100% certain!
Old Aug 3, 2012 | 11:25 AM
DodgeCares's Avatar
DodgeCares
Helmster,
I agree with the other posters in that you need to find the cause ASAP. Hopefully it is just the sending unit but if the oil pressure is indeed low then permanent damage to your engine can happen quickly.
Old Aug 3, 2012 | 12:29 PM
Helmster's Avatar
Helmster
Still now word on what it is, but the oil pressure was around 29 at idle and 45-50 while driving on the freeway... hoping its nothing serious. I will let everyone know once its diagnosed this am.
Old Aug 3, 2012 | 12:56 PM
thiggins's Avatar
thiggins
Those numbers sound good. Hopefully just a little data glitch.
Old Aug 3, 2012 | 01:26 PM
POWER SEDAN
Huh, my 5.7 runs around 60-65 PSI, my '07 did too. I know the LX models run around 48-50 PSI.
Old Aug 3, 2012 | 02:25 PM
thiggins's Avatar
thiggins
Normal PSI is 10-60 PSI depending upon RPM and Temperature.
