AVS Seamless Window Visors
Old Aug 26, 2012 | 03:16 PM
Worthey87's Avatar
Worthey87
Default AVS Seamless Window Visors
Hey everybody, had a lot of help from you all before. Hoping for a bit more. Just got some AVS Seamless Ventvisors for my 2010 Crew Cab Sport. The front windows have a forward flange on them that doesn't seem to fit quite right between the mirror mounting and the weather stripping. Wondering if I'm fitting it in right, or if there's a tip out there. Also worried when I dry fitted them the auto roll up on the window bounced back, I think it's because it senses something in the window. Anyone know if it's going to do that when I install them? Thanks in advance, there always seems to be a wealth of knowledge around here. I'm sure somebody's got a good solution
Old Aug 26, 2012 | 04:29 PM
WNDERR's Avatar
WNDERR
After you get them installed, and leave them in the full up position, for overnight, that issue will be resolved. IZt's not unusual to have to help the window go up the first time,after that, no problem
Old Aug 27, 2012 | 12:59 AM
Worthey87's Avatar
Worthey87
Thanks WNDERR, the only other issue I'm having is the fit in the front with the side view mirror and the stripping. There's a tab of material on the visor that doesn't seem like it fits right.
