Running Board Mount Issues
Old Sep 28, 2012 | 12:22 PM
mikenh82's Avatar
mikenh82
Default Running Board Mount Issues
Has anyone encountered issues with factory hardware breaking and pulling through the mount locations on the rocker panel on an 09 ram QC Laramie? We actually had to remove the passenger side running board because it was so bad. I have new running boards to install but will have to sure up those mounting locations to ensure that they don't pull through again. The factory mount locations just don't seem truely sturdy enough for my liking.
Old Sep 28, 2012 | 02:06 PM
seigell's Avatar
seigell
Yup... Happened to me with my Mopar SS 5in Running Boards...
I had to remove the Driver's side Running Board after the rear and center mounts started tearing through the metal around the mounting holes, causing the Running Board to "vibrate" while driving freeway speeds.
I'm still looking for a solution...
(And hating having to roll down the road with only the Passenger-side Running Board...)
Some of my previous posts on this issue:
https://dodgeforum.com/forum/4th-gen...ml#post2867454
https://dodgeforum.com/forum/4th-gen...ml#post2764026
https://dodgeforum.com/forum/4th-gen...ml#post2760780
Old Sep 28, 2012 | 02:15 PM
mikenh82's Avatar
mikenh82
I was thinking of bringing it to my body shop and having them fab up some reinforcement backers for both sides. If the passenger side blew out I can only assume that the driver side is not long for it either. These steps are rated for 350-375lbs but the sheet metal rockers certainly aren't!
Old Sep 28, 2012 | 03:27 PM
astroman54's Avatar
astroman54
My passenger side ripped off the truck when I got too close to a frozen snow pile. I put it back on using rivet-nuts from Mcmaster Carr after I straightened the sheetmetal out.
These are what I used:
http://www.mcmaster.com/#standard-rivet-nuts/=jhpjuf
Andy
Old Sep 28, 2012 | 06:22 PM
saberworks's Avatar
saberworks
I got aftermarket tube steps (raptor 4") based on recommendations on this forum and I'm pretty happy with the way they attach. They have backing plates and are attached at two points at each mount point. Maybe worth getting something like that because it doesn't seem to me that reinforcing the already destroyed sheet metal will help much. These still do attach through the sheet metal, though. I'd be much happier with something that mounts to the frame but *shrug* what can I do?
Old Sep 28, 2012 | 07:39 PM
Pedro Dog's Avatar
Pedro Dog
OEM side steps suck, they flex when I step on them so I just avoid them and I weight 185 lbs. I wouldn't have them, but my wife and mom sure like them. They also make it hard to slide under the truck for the oil change.
Old Sep 28, 2012 | 08:20 PM
RAMULAK's Avatar
RAMULAK
I posted about them peeling and then people chimed in about the attachment issue in this thread....
https://dodgeforum.com/forum/4th-gen...rs-chrome.html
Old Sep 28, 2012 | 09:15 PM
TheRiz's Avatar
TheRiz
Default Running Boards
The original boards on my 09 Ram got riped off doing some mountain climbing,riping about half of the set in nuts out.I got new 4in. black oval bars from Truckchamp.com. Had to knock out the remaining set in nuts in order to use their mounting system. Two bolts attached to a flat bar that uses the original holes.Had to hammer the pulled out spots flat but everything worked out very well.
Old Sep 28, 2012 | 09:45 PM
wellstep's Avatar
wellstep
I have had the same issue and found a solution I used heavier rivet nuts that have wings in the back to spread the load and used the Mopar Reinforcement Kit that no one seems to know anything about and that was about 2 years ago and no issues since I have a ton of information on it and have shared it with other members I will be happy to send to anyone that would like just send me a PM and I will also try and find my older posts.
Old Sep 28, 2012 | 09:47 PM
wellstep's Avatar
wellstep
Here is the orignal post. I have other info if needed as well. The little reinforcement kit made a huge difference.
https://dodgeforum.com/forum/4th-gen...-chrome-4.html
