Max tire size 2012 Ram 1500 quad
Old Nov 27, 2012 | 06:57 PM
svfd52243's Avatar
svfd52243
New Member
Default Max tire size 2012 Ram 1500 quad
I am wanting to install a 2.5" leveling kit and read that 35x12.50 tires will fit but i am concerened with rubbing. do some offroading down to the barn and things but mostly highway.
Posted from Dodgeforum.com App for Android
Old Nov 27, 2012 | 09:28 PM
Cmerritt84's Avatar
Cmerritt84
you may need spacers to avoid rubbing
Old Nov 27, 2012 | 10:03 PM
jacoblong44's Avatar
jacoblong44
dont use spacers. put a 285/65/20 or 295/60/20
Old Nov 29, 2012 | 07:46 PM
svfd52243's Avatar
svfd52243
New Member
ive heard that a leveling kit causes vibration in the front end. is this just a certain size or all?
Old Nov 29, 2012 | 11:55 PM
Tusakha's Avatar
Tusakha
Yes, it can cause vibration in the front while in 4WD.
Some get it, some don't. Some get it bad, some only get it slightly.
Will your truck have vibration when leveled? Maybe.
I used bilstein 5100's in the front of my TRX and maxed them out, and I ended up with a slight vibration under heavy accelleration in 4WD. Nothing that causes so much concern that I would not use 4WD, but I imagine I will wear through the stock u-joints faster. Once I do I will likely replaced them with some high angle ones.
Old Dec 1, 2012 | 02:09 PM
gr8rows's Avatar
gr8rows
I put rancho quicklifts on my trx and a 1" spacer on the rear and dont have any vibe. How often do you really drive around in 4 wheel drive? I live and work on a farm, and our winters are pretty good here, I rarely use 4 wheel drive. I am planning on 35x12.5's this spring.
