Old Aug 13, 2015, 08:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Puddle lamp
Old Nov 30, 2012 | 12:19 PM
ITALYRAM's Avatar
ITALYRAM
Default Puddle lamp
Hi, my driver side puddle lamp is out of work. Turn signal works but not the "white light". I have not found in any on-line catalog. Do you know where can i buy it?
Thanks in advance
Old Nov 30, 2012 | 04:48 PM
POWER SEDAN's Avatar
POWER SEDAN
Thanks in advance
There are replacement part numbers now for each LED lamp/directional through Chyrsler. I do have the part numbers for the "Tow Mirrors," (Courtesy of another member here) but the numbers for the other mirrors (Non-tow mirrors) will likely be different, since the design is different. I would check with a local dealer.
Old Nov 30, 2012 | 06:56 PM
Owensue's Avatar
Owensue
I don't think there are local dealers in Italy.
Old Dec 1, 2012 | 03:57 AM
ITALYRAM's Avatar
ITALYRAM
Correct. Dodge RAM is not imported in Italy so I need an US dealer that can ship to Italy. As I said I've tryed to search but with bad results...
Old Dec 1, 2012 | 09:19 AM
Ian Campbell's Avatar
Ian Campbell
If you dont have the tow mirrors then the puddle lights cant be bought with out buying a new mirror. I have the same problem but mine is full of water and everybody keeps telling me that the dealer said that you have to buy a new mirror. Im going to check this week at the dealer to find out for sure. I will get back to you if I found out different.
Old Dec 1, 2012 | 10:27 AM
BigBlueEdge's Avatar
BigBlueEdge
The 'puddle lamp' module is replaceable for some mirrors. It is also fixable with aftermarket LEDs. What seems to happen is that water gets into the module and corrodes the electrical connections. See this thread for details on how to fix and/or what parts to buy:
https://dodgeforum.com/forum/4th-gen...ed-lights.html
Rob
Old Dec 2, 2012 | 07:05 AM
ITALYRAM's Avatar
ITALYRAM
Thanks for replay. Yes the problem is the water inside. I will wait for more news about. The whole mirror is very expensive, expecially the laramie ones.
