OEM Mud Flaps
Old Dec 13, 2012 | 08:55 PM
kaw550's Avatar
kaw550
Default OEM Mud Flaps
I am thinking of getting a set of OEM mud flaps off ebay.
Do they require drilling?
Do they actually help keep the truck clean?
It is for an '09 quad cab
here are a couple of sets...
http://www.ebay.com/itm/2-SETS-FRONT...db068b&vxp=mtr
http://www.ebay.com/itm/2009-2010-20...82f854&vxp=mtr
Old Dec 14, 2012 | 01:08 AM
706jim's Avatar
706jim
Yes they will require drilling.
Yes, they help keep mud off of the fenders.
Old Dec 14, 2012 | 12:34 PM
LVRR's Avatar
LVRR
The OEM mud flaps do help keep the lower panels clean and also help prevent rock chips in the paint along the lower sides also. Front mud flaps will also help keep your side steps clean if you have them.
I had to drill the mud flaps bottom hole to help align it with the bolt hole in the truck, everything else lined up. You will have to remove the plastic piece that is bolted in place where you will install the flaps
Old Dec 14, 2012 | 05:46 PM
Patsfan's Avatar
Patsfan
Don't do it unless you are going to put a 3M or equivalent film under them. They carve into your paint. Try these.
https://dodgeforum.com/forum/4th-gen...mud-flaps.html
Old Dec 14, 2012 | 06:56 PM
martinez189's Avatar
martinez189
I installed the same OME mud flaps on my truck, but I didn’t drill into the truck. I just used what was there and have had no problem.
Old Dec 18, 2012 | 10:57 PM
SteveO44's Avatar
SteveO44
I installed the same ones on my truck. I didn't bother with drilling, the pre-drilled holes seemed to provide a tight enough fit on the flaps to bother with messing with drilling one more hole in each one.
Old Dec 19, 2012 | 04:38 AM
aepowell's Avatar
aepowell
I didn't have to drill any hole in mine. Ther was an extra hole in the flaps,but its not needed.
