Tap power outlet for radar connector
Old Dec 14, 2012 | 03:43 PM
quedogf94's Avatar
quedogf94
Default Tap power outlet for radar connector
I want to tap the power outlet for my radar detector. I'm installing the detector on my visor and plan on running wires down the pillar of the truck, is there a shortcut instead of running wires all the way to the fusebox in the hood?
2011 Laramie Crew cab with center Console.
Old Dec 15, 2012 | 12:53 PM
WESIDE's Avatar
WESIDE
Why not go with the blend mount and install it under your rear view mirror. Then you can tap the power into the powered rear view mirror. Just a thought. Did mine and it looks clean. You can get the power cable from........? cant remember. Im sure someone else here can recall.
