Climate Control Not Working
Old Jan 24, 2013 | 09:17 PM
Jimeeh1's Avatar
Jimeeh1
Default Climate Control Not Working
Just had a pleasant six hr ride from Vermont with no heat or ac(defrost). Was initially working this morning in sub zero temps but then just quit. Climate control lights are out and will not switch to warm or divert from floor but blower fan works. Assumed it may be a fuse but didn't find one blown that i would think would be associated as described in owners manual. One other thing I found was the headlights will not work in auto and when switched to this position, the dash headlight indicator goes out.
Any help would be greatly appreciated,
Thanks,
Jim
Old Jan 25, 2013 | 03:35 AM
topgun's Avatar
topgun
The sun sensor is connected in some way to the climate controls so that is probably the connection to the automatic headlights not working. Was having trouble viewing the wiring manual.
What year is your truck and does it have manual or auto climate control?
Old Jan 25, 2013 | 08:59 AM
Jimeeh1's Avatar
Jimeeh1
Manual Climate Control
Do you have a copy of the wiring schematic?
Old Jan 25, 2013 | 03:05 PM
LVRR's Avatar
LVRR
When you start your truck, do you hear any thumping or clapping noise coming from the HVAC system?
Old Jan 26, 2013 | 09:32 AM
Jimeeh1's Avatar
Jimeeh1
Well, started checking any fuse that may be remotely associated. Started the truck and it was working again. Great. I guess I have a loose connection. Anyone know where I can Get A schematic?
