Trailer Brake Controller
Old Aug 22, 2013 | 11:49 PM
NMRam's Avatar
NMRam
I have 3 connectors. Help! How do I tell if 2 are for the brake controller? I have a 2013.
Old Aug 23, 2013 | 12:12 AM
NMRam's Avatar
NMRam
Maybe the two bigger connectors are for the brake controller?
Old Aug 23, 2013 | 11:04 AM
Pedro Dog's Avatar
Pedro Dog
An easy way is to go to an auto parts store that sells Brake Controller adapter wire harnesses. One end of the harness connects to the big connector on your truck, the other to the brake controller. Look up the one for your year truck and either buy it or take a picture of the end that mates to your truck.
Here is a picture of the harness
http://www.etrailer.com/Accessories-...ha/3020-P.html
Old Aug 23, 2013 | 05:27 PM
JrFuel's Avatar
JrFuel
Pedro Dog, thanks for the info. I've been scratching my head about this for a long time! Another (dumb) question... how do I identify the pins (A1, A2, etc) on each connector? Are they labeled? Or does it start at the upper left, while looking into the connector? For example, A1 is the upper left, A2 is the upper right...
Thank you again for your help.
Old Aug 23, 2013 | 06:43 PM
Pedro Dog's Avatar
Pedro Dog
go to this website.
https://techauthorityonlinedemo.extr...ew/classic.htm
Once there, select year 2012, ram 1500 , etc, etc, for your model. Once you get the page loaded, scroll down to section 54, TRAILER TOW and click on the + sign. Once that opens, click on the ITEGRATED BRAKE CONTROL MODULE section, scroll half way down the page and you will see the wiring diagram with the 2 connectors and the controller. Click on the box for each connector, a menu will open up with 4 choices, 1) show component view, 2) show diagram of component, 3) show alternate diagrams and 4) show component location.
That's all the information you should ever need.
Old Aug 23, 2013 | 09:07 PM
JrFuel's Avatar
JrFuel
Pedro Dog, I ran a jumper from A3 to B3 like you said. The display read "Cf", or something like that. And it had a trailer symbol lit up, and an (!) flashing. I wasn't able to adjust the controller. And the trailer brakes did not work. Also, the display was on all the time. Without the key on and without out the trailer connected. Any ideas? Did I do something wrong?
Old Aug 24, 2013 | 12:20 AM
Pedro Dog's Avatar
Pedro Dog
No you did everything right. The signal for the B3 connector has to be switched on with the key. Jumpering from A3 it is the issue, my mistake in telling you to jumper it to b3. Run a key switched 12 vdc to be to fix it.
Old Aug 27, 2013 | 07:25 AM
iskybantilus's Avatar
iskybantilus
so could we make this controller work in a 2009 and just not have the evic display info as you are implying will hapen if you wire this way into a 2012 without the second connector? i do like the cleaner look of the factory controller.
Old Aug 27, 2013 | 09:53 PM
JrFuel's Avatar
JrFuel
Pedro Dog, I did what you told me. I ran a switched wire to B3. The display works now, however... it reads CF and it has a symbol of a trailer and (!) flashing. Plus, the trailer brakes do NOT work. Is there something else that needs to be done in order to make this controller work?? Help... please.
Old Aug 28, 2013 | 07:58 PM
Pedro Dog's Avatar
Pedro Dog
What year is your truck? If it's 2010 or newer and you only have the one big connector, I'm afraid you will also need to tap into the CAN Bus+ and the CAN Bus-. Others have done it by finding the wires under the dash. You're probably better off just getting an aftermarket one and fitting it in the cubby hole.
https://dodgeforum.com/forum/4th-gen...10-models.html
