Old Aug 14, 2015, 05:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
2013 Ram 1500 Outdoorsman suspension
Old May 28, 2013 | 11:31 PM
cole_gunderson's Avatar
cole_gunderson
Default 2013 Ram 1500 Outdoorsman suspension
Does anybody know if the Outdoorsman models have anything different about the suspensions from other Ram 1500 models? As far as I know they are exactly the same as all other models with the exception of the rear shocks ("extra heavy duty" compared to just "heavy duty" on other models)
I am finding that, when unloaded, my Outdoorsman can be a little skiddish over bumps - that is to say, the back end tends to step sideways when you hit a bump (especially around a curve or on gravel roads). It can be quite drastic and sometimes tries to steer you straight into oncoming traffic. I have friends with 2013 Laramie 1500s (no air ride) and they have no such problems. I suspect the "extra heavy duty" shocks are causing this and I think that maybe switching them out for the standard "heavy duty" shocks might help.
Any opinions/advice would be appreciated!
Old May 29, 2013 | 09:22 AM
jaflowers's Avatar
jaflowers
I believe front and rear shocks are the only difference, same as the TRX4s. Gives you a bit stiffer suspension but it pays off when you're off road.
Old May 29, 2013 | 09:33 AM
oldjeep's Avatar
oldjeep
Same thing can happen on my SLT - its a pickup truck with nothing in the bed, every one I've ever owned has tended to "skip" a little bit when hitting a bump on a corner.
Old May 29, 2013 | 10:23 AM
DodgeCACares's Avatar
DodgeCACares
Cole,
In addition to the rear extra-heavy-duty shock absorbers, the Outdoorsman also has the anti-spin differential rear axle. If you are having concerns, speak with your selling dealer maybe try test driving a similar vehicle or a 1500 without the extra-heavy-duty shock absorbers before swapping out parts to see if you notice a difference.
Old May 29, 2013 | 09:14 PM
cole_gunderson
Originally Posted by DodgeCACares
Cole,
Thanks for the response!
So the coil springs, linkages etc. are identical for all Ram 1500 models?
Old May 30, 2013 | 10:00 AM
DodgeCACares
Cole,
No they will not all be identical because, for example, there are roughly 11 different springs that could be on a 2013 1500. It depends on the special features and options that the vehicle was built with such as, if the vehicle is 2WD or 4WD, the box size, ect.
